No spark after AFC removed.
Old Jan 28, 2004 | 11:45 AM
arpa's Avatar
Default No spark after AFC removed.
As the topic states, the car ran fine while the VAFC2 was in. Took it out, now the car will turn over but is getting no spark. Checked the connections at the ecu where the AFC was connected, everything looks tight. I checked thru the archives but didn't see anything that would qualify for this issue, so hopefully somebody has had this problem before and can leed me in the right direction.
Old Jan 28, 2004 | 12:18 PM
Jimmy's Avatar
Global Moderator
double check...its ovasly something u did
Old Jan 28, 2004 | 12:31 PM
arpa's Avatar
Its looking like its something that has nothing to do with it now. I rewired the AFC back into the car and its the same issue. Swapped ecu's with one I know works, same problem. Checked all known fuses so now I guess its time to crack open the distro. Yay.
Old Jan 28, 2004 | 01:25 PM
arpa's Avatar
Alright, solved the problem at hand. Had nothing to do with the AFC, something in the distributor went bad.
jdsmooth
Mar 7, 2008 04:59 PM
A.E Motoring
Aug 16, 2006 07:04 PM
thatruhotsauce
Jun 22, 2005 10:31 PM
my2sons
22
Feb 8, 2005 08:17 AM
blacktallon2000
Jul 21, 2004 03:50 PM
