the rest of my p.s. story...
well i did the test today and found no leaks or anything. before i started the car the fluid was chillin at the lower line, after a few turns it had climbed to less than an inch from the top of the resevoir, is that normal w/ or w/o p.s.? i also forgot to include in my original post that the entire resevoir, top (gray part), and cap have fluid on them. is it possible the fluid is just coming out of the cap? this is making me think that i dont have a leak, that it is just coming out of the top. can i fix this? and do so by keeping my car w/o ps? thanks
https://honda-tech.com/zerothread?id=747706
Modified by LudeTuner at 12:18 PM 1/28/2004
if you aren't running p/s, why don't you just get rid of it all together?
i think you are supposed to loop the lines in the p/s rack somehow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">if you aren't running p/s, why don't you just get rid of it all together?
i think you are supposed to loop the lines in the p/s rack somehow</TD></TR></TABLE>
i would but i have no idea how to do it, ive only seen pics. i need a parts list and the DIY instructions if anyone has got them.
yeah I would guess that the fluid could be leaking any number of places. Reason being because you still have the pump connected to the system. But... you have the belt off so the pump is not operating...
You need to bypass the pump. As you are turning you are building up pressure in lines that do not normally have much pressure in them. Follow the lines and connect the hoses that go into the pump with those that are coming out of the pump. know what I mean?
thats it? before i saw a post about someone taking the whole system out and then they put new lines and a resevoir right above their steering rack, but that seem too confusing. after i connect the lines and drop the pump should i still run p.s. fluid in the system, or should i use something else?
yeah I would leave the fluid in there. Your best bet would be to take the lines coming right out of the rack and just connect those together. This will make it a little easier but it won't be as easy as a manual rack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeTuner »</TD></TR><TR><TD CLASS="quote">does anybody have any pics or a write-up of this? they tend to make it easier...</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=700300
here is a thread that i started and i also perfomed a mod. read what i wrote at the end of the thread and it will help some.
also check out this thread for some very helpful information. the integra racks are different but the concept is still the same
https://honda-tech.com/zerothread?id=184202
good luck
good luck
ok so i found the lines that i need to bypass but the green one is made of all metal... am i supposed to cut through it? oh yah and if it makes a difference i am looking at it from the bottom of the car. im planning on doing the bypass, but doing a closed loop for now. and were is that speed sensor(what does it look like and what color is it?)? thanks
SlowPokeEg
Jul 22, 2011 09:09 AM
Thunder Cat
Dec 9, 2005 03:39 AM
01itr518
Jan 2, 2002 06:58 PM
