why is the oil pressure gauge so important?
Old Jan 28, 2004 | 11:02 AM
Tad's Avatar
Tad
Default why is the oil pressure gauge so important?
easy quesiton I'm sure you guys can answer for me
thank you.
Old Jan 28, 2004 | 11:18 AM
gots_a_sol's Avatar
well if your driving along and you happen to notice your oil pressure take a dive, pretty good change that something just broke/fucked up
now if you didnt have that gauge, how would you know what just happened until the engine went ....cough.....sputter......flatline..... ?
Old Jan 28, 2004 | 11:20 AM
m R g S r's Avatar
Default Re: (wants_a_sol)
It's like any other gauge, they are not necessray, but really help to monitor your engine and ensure that everything is fine.
Old Jan 28, 2004 | 12:03 PM
Tad's Avatar
Tad
Default Re: (m R g S r)
ok,
simple enough.
well in that case,
what are the types of problems that occur that cause your oil pressure to drop?
is it something to due with the oil delivery system?
like maybe you have your feed/return line setup incorrectly,
or just something that happens when **** goes bad... like a blown ring or somethin?
(learning is fun )
Old Jan 28, 2004 | 12:06 PM
Egg-weezy's Avatar
blow your head gasket, piston, oil pan seal, or just plain blow your motor. It important if your using anything other than a stock setup (turbo, or NOS) Just another way to monitor your car.
Old Jan 28, 2004 | 12:17 PM
Honda Hick's Avatar
Default Re: (Tad)
You can tell from your oil pressure if your engine is totally warmed up. Your coolant temp might be up to normal but it takes longer for your oil pressure to come down at idle.
Your oil pressure would go down if you ran out of oil (doh), like from a leak. It will also go down if your oil pump is taking a ****. One guy on here had pieces of headgasket stuck in an oil journal and it starved the engine of oil. BTW don't drive your car if you have no oil pressure .
Old Jan 28, 2004 | 12:21 PM
*Boostwerks*'s Avatar
Simply put...
Oil is the blood of your engine.
Isn't it obvious?
Old Jan 28, 2004 | 07:03 PM
Tad's Avatar
Tad
Default Re: (Bryson)
aah ok,
much clearer now.
basically a drop in oil pressure is what your keeping an eye out for with the gauge.
and this basically happens when things come loose in the engine.. something brakes.. a seal goes.. etc
sounds about right?
Old Jan 29, 2004 | 01:52 AM
Tad's Avatar
Tad
ttt
pcguy760
Jul 2, 2006 10:17 AM
IneedBoostInTheCoupe
31
May 13, 2005 08:57 PM
May 13, 2005 08:39 PM
GPoodle
Nov 29, 2003 12:10 AM
itr501
Sep 29, 2001 08:04 PM
