Broken valve cover bolts
you need a new stud. this is a common problem with B series motors. Call up Len on H-T or a local dealer and order a few and extras.
For future reference, I think you are supposed to wait til the motor is cool and not hot when torqueing these nuts/studs.
Go to sears...get the easy-out screw extractor...looks like this...
You use the smallest one...it works...I've done it before. You use the drill bit end to drill a hole in the center of the bolt...then...flip it around to the threaded side...stick it in the hole...and back the screw out...took me 5 mins. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charjacq »</TD></TR><TR><TD CLASS="quote">The bolt is cut flush with the valve cover. I'm guessing I could simpy remove the valve cover and replace the bolt with a pair of vice-grips?</TD></TR></TABLE>
Pull the valvecover off and your questions will be answered, no vice grips or easy outs involved. Just get a new stud from Honda/Acura.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR »</TD></TR><TR><TD CLASS="quote">And remember to torque them right properly. 22 ft/lbs I beleive is what it needs to be on.</TD></TR></TABLE>
22ft/lbs...riiiiight. No wonder the bolt snapped! Try again.
what the......
NIce missinformation.
just take the valve cover off and unbolt that bitch from the head replace. then
torque it to what the helms manual says
what the......
NIce missinformation. just take the valve cover off and unbolt that bitch from the head replace. then
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar »</TD></TR><TR><TD CLASS="quote">over the spark plug cover, or on the outer part of the valve cover itself?</TD></TR></TABLE>
i broke one nut over the spark plug cover this weekend.
any way to fix that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR »</TD></TR><TR><TD CLASS="quote">And remember to torque them right properly. 22 ft/lbs I beleive is what it needs to be on.</TD></TR></TABLE>Tripling the torque isnt the same thing as triple checking...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>I think he meant the stud, that's supposed to be torqued into the head at 22 ft./lbs. At least i hope that's what he meant.
I have never heard of anyone doing this since I have been on here. Two days after I do it this thread pops up. Weird huh? I need to order another stud also.
Welcome to the "f*ck !! I broke a stud" club
Do like everyone is saying, pull the valve cover, remove the stud with a vise grip and install a new one. Word of caution: TORQUE IT LIGHTLY !! No more than 8lbs/ft or you'll be starting all over again
Alright, thanks guys. Anyone know which stud I could use from a honda dealer? It's for a JDM type-R. I'm guessing B16 studs would match too? I'm just too lazy to go the the acura dealership, I have to go to honda anyway.
Vice grips? Use a 10mm or 12mm box wrench or deep socket instead. The outer studs are flange-nutted at the base where they thread into the cap plates.
Same thing with the inner valve cover studs (12mm deep), only you replace the entire cam cap bolt.
The parts should be universal P30 or PR3 parts.
And, you can still snap bolts and studs with a torque wrench if you swing it too forcefully or too fast. Use slow, steady pressure on the torque wrench, moving from the 1 o'clock to 5 o'clock position (or mirror-imaged for left-handers). Or, you can just forget the torque wrench and do it with a short 3/8" drive ratchet. It's not a critically-stressed part of the engine so proper fastener tension stretch isn't necessary....only proper retention.
Valve Cover Stud/Cam Cap Bolt (long - middle) [6x1.00] 90014-PR3-000
I don't know the part number for the outer studs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boges »</TD></TR><TR><TD CLASS="quote">I think he meant the stud, that's supposed to be torqued into the head at 22 ft./lbs. At least i hope that's what he meant.</TD></TR></TABLE>
Yeah thats what I meant, if its the stud that goes on the cam caps. Sorry if I confused some people.
Yeah thats what I meant, if its the stud that goes on the cam caps. Sorry if I confused some people.</TD></TR></TABLE>
We're just playing with ya
I need to order a couple again just to have in the box.
fwiw - I've never torqed one of these things yet. Even a mini torque wrench can be 'off' enough to snap these little turds. They should have made them strong enough for ~15-20ft/lbs so this doesn't happen
I need to order a couple again just to have in the box. fwiw - I've never torqed one of these things yet. Even a mini torque wrench can be 'off' enough to snap these little turds. They should have made them strong enough for ~15-20ft/lbs so this doesn't happen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BudMan »</TD></TR><TR><TD CLASS="quote">I've never torqed one of these things yet. Even a mini torque wrench can be 'off' enough to snap these little turds. They should have made them strong enough for ~15-20ft/lbs so this doesn't happen
Found this out the hard way (on another car). Torque wrenches are often very inaccurate around 10 ft. lbs.
It's probably best to hand tighten using a wrench with a short handle.
</TD></TR></TABLE>Found this out the hard way (on another car). Torque wrenches are often very inaccurate around 10 ft. lbs.
