clutch questions
Old Jan 28, 2004 | 09:27 AM
95civicracer's Avatar
Default clutch questions
my friend has a 96gsr and the clutch is really stiff and one of my other friends had a 97 dx and his clutch was stiff as well, why the hell does my clutch pedal(95 civic d16z6 hydro clutch) feel like a bowl of mush. yes i bled the system, and the clutch is fairly new. if you guys have any ideas let me know.
Old Jan 28, 2004 | 09:30 AM
ProEater's Avatar
Default Re: clutch questions (95civicracer)
what kind of clutch do you have?
Old Jan 28, 2004 | 09:36 AM
honda
Old Jan 28, 2004 | 09:41 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (95civicracer)
what clutches do your friends have?
Old Jan 28, 2004 | 09:46 AM
TeamNextGenChris's Avatar
as long as it's functioning correctly i wouldn't worry about it.
my GF's clutch in her stock 97 EK LX feels quite a bit stiffer than her sister's stock 99 EK EX...both still have the OEM clutches in them.
could be somebody installed an aftermarket clutch that has higher or lower than stock stiffness PP fingers.
improperly lubed pivots for the clutch release fork could probably also add a little effort.
chris
Old Jan 28, 2004 | 09:52 AM
they both have honda clutches. i need to drive another car just like mine to see if that it the way it is supposed to be. my car has always been like this so i guess it is normal. Is there any way i can make it stiffer without getting a new clutch like adjust it possibly
Old Jan 28, 2004 | 10:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicracer &raquo;</TD></TR><TR><TD CLASS="quote">they both have honda clutches. i need to drive another car just like mine to see if that it the way it is supposed to be. my car has always been like this so i guess it is normal. Is there any way i can make it stiffer without getting a new clutch like adjust it possibly
no,if everything is in good condition,there's nothing you can do to make it stiffer.
why would you want it stiffer anyway?
chris
Old Jan 28, 2004 | 10:07 AM
DJtal Chaos's Avatar
My roommate and I have the exact same kind of car(2k ex), and our clutches are as different as night & day. Mine is a lot stiffer than his, and both are original Honda parts. If I were you I wouldn't worry about it, every clutch is different. If you really want a stiffer clutch you can grab a helms manual, it'll show you how. If I have time I might be able to grab mine on break (i'm at work right now ) and let you know.
And it has nothing to do with the actual clutch, it's your pedal that you want to change
Old Jan 28, 2004 | 10:10 AM
i am not worried really i just like the stiff clutch. but thanks chaos because my manual got borrowed and i have not seen ever since then.
Old Jan 28, 2004 | 10:26 AM
np mang. Thats why I never lend mine out.
Old Jan 28, 2004 | 11:24 AM
Default Re: (DJtal Chaos)
Possible reasons:
1. No fluid in reservoir
2. Faulty clutch master cylinder, release cylinder, or hydraulic line
3. Broken release bearing or fork
I wish I could help more, but all I could find was my 96-2000 book. Hope this helps. Try to get your book back or buy another one.
Old Jan 28, 2004 | 11:53 AM
ieatrice's Avatar
dude, i asked the same question last week! i drive a 95 civic si.. which is a d16z6 like yours. the clutch isn't very stiff compared the GSR's and other civic's i've driven. i always thought i needed a new clutch.. now i guess it's normal. it's still functional and all, but after driving a stiff clutch, i like it.. it rides a lot smoother too for some reason.
iiPancho
Dec 29, 2008 11:53 AM
Philip
Jul 5, 2003 12:14 AM
MachAF
Mar 17, 2003 10:24 AM
MachAF
Mar 14, 2003 03:46 PM
Chris93Si
Mar 9, 2003 02:43 AM
