what color paint matches the red jdm valve cover?
Old Jan 28, 2004 | 08:51 AM
97civic123's Avatar
Default what color paint matches the red jdm valve cover?
I wanted to paint my valve cover the same as the jdm red ones. anyone know what color can spray paint would match that color?
Old Jan 28, 2004 | 08:53 AM
PotatoePAPA's Avatar
Default Re: what color paint matches the red jdm valve cover? (97civic123)
red jdm valve cover paint...duh
Old Jan 28, 2004 | 09:01 AM
Caveman74's Avatar
I think it is a powdercoat?
Old Jan 28, 2004 | 09:03 AM
Plan B's Avatar
Default Re: what color paint matches the red jdm valve cover? (Caveman74)
high temp engine paint, just get whatever looks close.
by the way, save your money and don't rice your car out.
PhreeStyleHB's Avatar
paint is gonna look ugly, get it powdercoated. or just buy one.
Old Jan 28, 2004 | 09:17 AM
dwnthehatch's Avatar
Default Re: what color paint matches the red jdm valve cover? (PhreeStyleHB)
Old Jan 28, 2004 | 09:19 AM
Grimm's Avatar
Default Re: what color paint matches the red jdm valve cover? (dwnthehatch)
get red high temp paint.. put some chapstick on the lettering. then paint away... use an exacto to help peel away the lettering, should be easy due to the chapstick... looks good IMHO...
Old Jan 28, 2004 | 09:43 AM
esoterEK..'s Avatar
you<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>you can buy it from summitracing.com
Old Jan 28, 2004 | 02:39 PM
97civic123's Avatar
thanks dwnthehatch that's all i needed
Old Jan 28, 2004 | 02:46 PM
Hybrid96EK's Avatar
Default Re: what color paint matches the red jdm valve cover? (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm &raquo;</TD></TR><TR><TD CLASS="quote">get red high temp paint.. put some chapstick on the lettering. then paint away... use an exacto to help peel away the lettering, should be easy due to the chapstick... looks good IMHO...</TD></TR></TABLE>
No need to use high temp paint. Also no need to rub anything on the lettering. Clean it and prime it first. Then paint it up. Clear coat it and then use a razor blade to remove the paint off the lettering. Will look 10x's better the smearing something on the lettering and you will actually get paint on the sides of the letters, like it should be. It will look factory if you select the correct color. High temp paint tends to be too thick, and will remove the wrinkle finish from the cover. Thin coats of normal paint will duplicate the Honda finish almost exactly.
Old Jan 28, 2004 | 02:54 PM
H22A EG6's Avatar
Default Re: what color paint matches the red jdm valve cover? (EGkwazhimoto)
how does that stuff look on the valvecover
Old Jan 28, 2004 | 02:55 PM
Ricey McRicerton's Avatar
Default Re: what color paint matches the red jdm valve cover? (H22A EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 &raquo;</TD></TR><TR><TD CLASS="quote">how does that stuff look on the valvecover</TD></TR></TABLE>
Great. I've seen some of them that look OEM.
thecruzs2007@yahoo.com
Jan 3, 2010 04:55 AM
b0mb5
Aug 24, 2008 08:16 PM
Edward
Mar 12, 2006 10:31 PM
crj_lll
Jul 21, 2005 12:31 PM
acatak
May 3, 2002 04:03 PM
