what color paint matches the red jdm valve cover?
I wanted to paint my valve cover the same as the jdm red ones. anyone know what color can spray paint would match that color?
Re: what color paint matches the red jdm valve cover? (Caveman74)
high temp engine paint, just get whatever looks close.
by the way, save your money and don't rice your car out.
Re: what color paint matches the red jdm valve cover? (dwnthehatch)
get red high temp paint.. put some chapstick on the lettering. then paint away... use an exacto to help peel away the lettering, should be easy due to the chapstick... looks good IMHO...
you<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>you can buy it from summitracing.com
Re: what color paint matches the red jdm valve cover? (Grimm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grimm »</TD></TR><TR><TD CLASS="quote">get red high temp paint.. put some chapstick on the lettering. then paint away... use an exacto to help peel away the lettering, should be easy due to the chapstick... looks good IMHO...</TD></TR></TABLE>
No need to use high temp paint. Also no need to rub anything on the lettering. Clean it and prime it first. Then paint it up. Clear coat it and then use a razor blade to remove the paint off the lettering. Will look 10x's better the smearing something on the lettering and you will actually get paint on the sides of the letters, like it should be. It will look factory if you select the correct color. High temp paint tends to be too thick, and will remove the wrinkle finish from the cover. Thin coats of normal paint will duplicate the Honda finish almost exactly.
Re: what color paint matches the red jdm valve cover? (H22A EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">how does that stuff look on the valvecover</TD></TR></TABLE>
Great. I've seen some of them that look OEM.
thecruzs2007@yahoo.com
01-03-2010 04:55 AM
Edward
03-12-2006 10:31 PM
