sohc cam gear
im buying a cam gear for my d16z6 and i wanted to know if anything else has to be upgraded to make a difference with the cam gear. i have i/h/e and soon a im maybe plus the cam gear. is anything else needed. thanks.
you really wont see too much of a difference with a cam gear.....maybe 2whp at the very most. if you were pushin serious hp from an sohc then it would be benificial. but if used right it doesnt hurt
which cam gear are you getting?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEGHatch6 »</TD></TR><TR><TD CLASS="quote">im pickin up a red aem cam gear for 50 bucks, figured it couldnt hurt.</TD></TR></TABLE>red one will def hurt you...
Hella_JDM, they all have 3 bolts, old and new...to the original postee, I think Hella is sayin make sure it is indexed properly. Back in the day, AEM indexed some gears wrong..., also, make sure the marks for tdc's match up to stock (keyway should be inline with 12 oclock mark, etc...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECMaster »</TD></TR><TR><TD CLASS="quote">i'm kinda n00b to cam gears, what are they good for, will the change the opening times of the intake and exhaust valves? can i mount them on a stock d15 sohc vtec engine?</TD></TR></TABLE>
adjustable cam gears allow you to easily adjust the timing ... could possibly gain some ht by a retard. Good for boosting'
on sohc, adv. cam bring power band down, ret. cam brings power band up...depends on tune and cam profile if you will make power at any certain setting.
