personal experience w/ swap, hmotors =\ & clutch debate! MY 2 CENTS
o beegezus..ever since i put in my motor from h motors...ive been having a lot of problems...first my egr...then my clutch...=\ iono anymore...jus wanted to letcha know what im going through
an h22a swap is harder than it seems...
but they do warranty their motors and give u replacement parts if they are bad but u must send in your old one
well as for the clutch...i just bought a ACT heavy duty pressure plate w/ performance street disc...in other words...stage 2...
now ive been hearing that exedy makes the best clutches...is that true? later on in the future, should i stick to my clutch or upgrade and buy an ogura/exedy?
thanks
an h22a swap is harder than it seems...but they do warranty their motors and give u replacement parts if they are bad but u must send in your old one
thanks
the act HDSS one u have is great. Its not any worse than the exedy racing organic, both are great clutches, so stick with what you have, i promise you, you will be happy
it has nothing to do with hmotors, all of the swap stores are basically the same, u gotta just hope u get an engine who had an owner that took care of it, swap shops arent gonna open it up to tell u how it looks, they just check compression and make sure all sensors are good, u cant really ask for more
b16_madman
18
Oct 6, 2003 07:50 PM
