checked the check engine light 61
Old Jan 27, 2004 | 06:28 PM
onesiksupra's Avatar
Default checked the check engine light 61
Primary Heated Oxygen Circuit
-Slow response
CAUSE -
Primary HO2S sensor
Exhaust System
I got a serious exhaust leak between the Wastegate piping and the manifold. Could this be why IM gettin a 61 or is it more likely to be a bad 02 sensor ?
The primary sensor is the one before the cat or after ?
Old Jan 27, 2004 | 06:40 PM
satan_srv's Avatar
Default Re: checked the check engine light 61 (onesiksupra)
primary is before...if most of your exhaust gas is leaking out that would explain it..slow response like slow flow readings?
Old Jan 27, 2004 | 06:50 PM
Default Re: checked the check engine light 61 (satan_srv)
I gota FMax turbo kit - and need replacement Gaskets between the turbo and mani and wastegate. Where would i get those ?
jodyboy
Aug 2, 2012 06:00 PM
1.8Coupe
Aug 7, 2008 07:48 PM
Bizarre
Jul 9, 2007 02:17 PM
97exd16
19
Jul 31, 2005 08:06 PM
Hybrid
Aug 17, 2003 08:55 PM
