crooked steering wheel
Old Jan 27, 2004 | 05:46 PM
socalep3
Guest
Posts: n/a
Default crooked steering wheel
what part do i need to fix if my steering wheel is not straight when i am gogin straight
Old Jan 27, 2004 | 05:58 PM
giCe's Avatar
Default Re: crooked steering wheel (socalep3)
alignment?
Old Jan 27, 2004 | 06:09 PM
Peking's Avatar
Default Re: crooked steering wheel (giCe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giCe &raquo;</TD></TR><TR><TD CLASS="quote">alignment?</TD></TR></TABLE>
Um...yeah. Also keep in mind that the wheel will never be perfect. Our cars are pretty sensitive when it comes to uneven roads.
Old Jan 27, 2004 | 07:03 PM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by socalep3 &raquo;</TD></TR><TR><TD CLASS="quote">what part do i need to fix if my steering wheel is not straight when i am gogin straight</TD></TR></TABLE>
FYI, If the vehicle is less than 12 months old and has under 12,000 miles on it, Warranty will pay for an alignment...as long as there aren't signs you hit something.
Old Jan 27, 2004 | 07:50 PM
Eee Pee's Avatar
Default Re: crooked steering wheel (GreenBean)
Or crawl underneath and twist both tierods the same direction a quarter turn.
As to which direction , i can't tell you as you haven't said which way the wheel is cocked.
As long as you turn them both the same amount, your alignment won't change.
(A quarter turn is just an estimate, it may be more, it may be less)
Old Jan 27, 2004 | 07:57 PM
acuratech's Avatar
Default Re: crooked steering wheel (Eee Pee)
Seeing that you have aftermarket suspention components, warranty will not cover an alighnment. Just get an alighnment and that will do the trick. My EP is all stock, and i alighned the damn thing 2 times before i finally got it to go straight. Thats how sensitive these EPs are.
kharned08
Honda Civic (2001 - 2005)
Mar 4, 2008 01:44 PM
Reza^
Jul 19, 2007 12:05 PM
jivi
Jun 30, 2007 11:13 AM
7808
11
Sep 1, 2006 03:08 PM
Nextelbuddy
May 20, 2005 07:21 PM
