Knock sensor pin out needed!
ok guys here we go. i have a 95 accord that i put a 01 h22 (h22a4). i used a p13 computer (ECU) out of a 95 prelude to keep it odb1. the problem is i used the 95 honda accord harness that was in the car. it has everything except a knock sensor wire. so i ran a wire from the back of the motor off of the sensor to the ecu inside. another honda-tech member gave me the pin out diagram by color and pinout #'s of the p13, but the colors are all wrong due to the accord colors and i dont know how the pins are going because i have no pattern to go by. i need a picture of the <U>plug side</U> with a pin out description on where exactly the knock sensor is located so i can plug and go!!
please help
shane
Modified by forcedaccord95 at 2:35 AM 1/28/2004
please help
shane
why do you need a picture...the knock sensor is D3 on the ecu..
the d plug goes from
D1->D21
D2->D22
so the D3 is on the top 2nd over
D1->D21
D2->D22
