I BEG YOU FOR SOME HELP...PLEASE JUST LOOK IF NOT MORE......
Old Jan 27, 2004 | 03:23 PM
DRKSol's Avatar
Default I BEG YOU FOR SOME HELP...PLEASE JUST LOOK IF NOT MORE......
I have a 1994 Honda Civic Ex(d16z6) w 115.000 miles. Today i left work and my
car felt like it was skipping on the road. first i thought it was because of the snow
but i took it on some dry pavment and it still did it. when you pull off in first gear
and you go slowly it feels like the tires are skipping or vibrating. (it's almost like if
you put the car in a high gear and try to drive, the feeling of it when its about to
die.) My clutch is about gone but i'm not sure if thats it becasue if i switch gears
fast and let the clutch off fast it wont do it but if i drive normal it will. also my
clutch lets off almost at the top. My other problems are the crankshaft bearings
and water pump but im not sure if that would contribute to that problem.
Thank You In Advance,
Haydn
Old Jan 27, 2004 | 03:24 PM
976's Avatar
976
New User
Default Re: I BEG YOU FOR SOME HELP...PLEASE JUST LOOK IF NOT MORE...... (jh)
Check for bent wheels.
Broken drive axles.
Old Jan 27, 2004 | 03:27 PM
NonovUrbizniz's Avatar
Loved
you probobly have snow jammed in your wheels... the weight will "unbalance" the wheels and make it jidder when you're driving it...
That's the most likely thing I can think off.
Old Jan 27, 2004 | 03:32 PM
JimmyAtlantis's Avatar
You seem to know what your problems are. Just get them fixed. It's mainly your clutch, but get the other problems fixed ASAP!
The reason I'm saying clutch is the way you described how it is when you "pop" it after a shift. The "pop" is giving the clutch disc enough force to grab the flywheel that little bit more. You really need to understand how a clutch works to see what I'm saying.
http://auto.howstuffworks.com/clutch.htm
Old Jan 27, 2004 | 03:34 PM
Default Re: I BEG YOU FOR SOME HELP...PLEASE JUST LOOK IF NOT MORE...... (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">you probobly have snow jammed in your wheels... the weight will "unbalance" the wheels and make it jidder when you're driving it...
That's the most likely thing I can think off.</TD></TR></TABLE>
That's good thinking too! It'll happen if more if you don't have wheel covers.
Old Jan 27, 2004 | 03:42 PM
pdiggitydogg's Avatar
snow in wheels happened to me just a few weeks ago
came from snow-donuts
took the wheel off and banged all the ice off....problem solved
Old Jan 27, 2004 | 03:43 PM
JDMlyfestyle's Avatar
check your lugnuts
Old Jan 27, 2004 | 03:45 PM
DRKSol's Avatar
i dont have ice in my tire wall. i checke to see if it was that. oh yeah this morning i kinda slide into a curb on the passenger side but it wsnt anything big i was going about less than ten miles per hour. do you think it has anything to do with my clutch.?
Old Jan 27, 2004 | 03:47 PM
chameleon's Avatar
Default Re: (pdiggitydogg)
nevermind, my help would prob be way off in left field.
Old Jan 27, 2004 | 03:49 PM
DRKSol's Avatar
lugnuts????????why, to see if they are loosen?
Old Jan 27, 2004 | 03:53 PM
Loved
by tire wall.. you mean INSIDE the backside of the wheel... not the wheel well right?
Because snow inside the wheels wouldn't be something you could really see from the front unless you have pretty open wheels...
Hitting a curb at 10mph could CERTAINLY bend something enough to make it shake... not to mention it could have knocked off some wheel weights.
Old Jan 27, 2004 | 04:02 PM
Ricey McRicerton's Avatar
Sounds like it's time to pull of those wheels and check for bends, missing tire weights and tons of ice/snow packed in them. Check on the side you hit the curb with for bent LCA and broken axles as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">Hitting a curb at 10mph could CERTAINLY bend something enough to make it shake... not to mention it could have knocked off some wheel weights.</TD></TR></TABLE>
After letting us in on that little secret of his, I would certainly agree. That's plenty to f your **** up. Still though, get all that other **** fixed.
Old Jan 27, 2004 | 04:08 PM
DRKSol's Avatar
Default Re: I BEG YOU FOR SOME HELP...PLEASE JUST LOOK IF NOT MORE...... (JRI94)
Ok thanks for the help i'll check it all over again tomorrow afternoon. thanks
Old Jan 27, 2004 | 04:30 PM
snoochtodanooch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">
After letting us in on that little secret of his, I would certainly agree. That's plenty to f your **** up. Still though, get all that other **** fixed. </TD></TR></TABLE>
agreed, compounded with the snow is bad news.
Old Jan 27, 2004 | 06:16 PM
DRKSol's Avatar
Hey guys thanks for the advice. i took her out tonight and lighted it up, just because i was mad, well it is amazing a huge piece of ice fell when i lit up the tires.
thanks for the advice though
Lori Olivero
Honda Civic (2001 - 2005)
Apr 21, 2016 09:36 PM
Honda Rules
Apr 22, 2007 05:36 PM
not2fast
Jan 8, 2005 03:08 PM
-BlueGSR-
May 1, 2003 09:27 AM
paybac4223
Oct 28, 2002 03:01 PM
