My buddy needs a new water pump on his 88 honda accord....
Hey, im curious as to some prices, and what all is involved, would it be worth doing and ****? thanx!
remove the belt and move the cruise control unit out of the way if you want more room then remove the motor mount and place a jack under the oil pan and jack it up a little bit till the water pump is more easily accessable then remove the 10 mm bolts in the pully then the 10 mm bolts on the water pump and remove it then reverse the steps to install it it is actually pretty easy to change
