NEED pics of civic on Eibach Pro-kit
I have had some suspension issues since I rebuilt the entire front end of my hatch with polygraphite bushings. I took the car to Dallas Frame and Align and they said I need to change the tire size before they could give an accurate reading. They did tell me the following though. Rear Trailing arms are not bent, rear end can be shimmed into specs, worst:right rear -3deg camber, front end needs camber adjusted, worst:front right -3.24deg camber. All this can only be done if the tire are changed to a lower profile. I have 185/70/14s dropped on the PK/konis na. I need pics to see what the clearance should look like and how the wheel sits in regard to the fender lip on the front end. THanks.
esoterEK..
Suspension & Brakes
Jul 29, 2008 01:26 PM
