Does V6 exhaust bolt up to 4 cyl on 6th gen ???
I tried a search and couldn't find anything, and im sure its been asked before.
Has anyone out their tried bolting up a V6 exhaust to a 4 cylinder. I want to take the midpipe and the rear end off a V6 and bolt it up to my 4cyl 5spd.
Yes I do realise this does nothing for performance, i am purely doing this 4 looks.
Any help would be appreciated
Thanks
Thanks
as far as i know, yes... but, there aren't any hangers for the driver's side muffler and pipe, so you would need to take it to a muffler shop so they can weld something on there...
So the header outlet on the 4cyl and the V6 are the same size ?
Maybe that would have beena better question.
I believe it's only cat-back that would be same. If you simply want the dual mufflers, cat-back is all you would need.
Side note: you'll probably want to get the exhaust from the sedan if your's is a sedan, or from a coupe if your's is a coupe. I know that some aftermarket exhausts are slightly different lengths for the coupe and sedan, since the coupe is slightly shorter in the rear.
SpoonyGSR
21
Apr 20, 2005 10:13 AM
DazDillinger
Jun 14, 2004 02:01 PM
