ECU Questions!!
Old Jan 27, 2004 | 11:57 AM
MUGEN_B16CIVIC's Avatar
Default ECU Questions!!
Ok, heres my ?'s :
What is the ECU for a B16a3???
also i'm going to chip my ECU and what would be the best VTEC engadgment be for a B16 with stock cams...also what would be the best RED LINE engadgment??
Old Jan 27, 2004 | 12:25 PM
Zer0DazE's Avatar
its a p30
on a stock motor, a stock program will be fine
Old Jan 27, 2004 | 02:23 PM
Katman's Avatar
Default Re: ECU Questions!! (MUGEN_B16CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_B16CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">Ok, heres my ?'s :
also i'm going to chip my ECU and what would be the best VTEC engadgment be for a B16 with stock cams...also what would be the best RED LINE engadgment??</TD></TR></TABLE>
I concurr with Zer0DazE commment...
stock P30 vtec point is 5500rpm, redline 82-8300rpm (8500rpm wont hurt tho).
Old Jan 28, 2004 | 05:18 AM
Default Re: ECU Questions!! (Katman)
yea but, im going to chip mine so i'm not going stock vtec, and redline....but how low of a VTEC can i have without messing with my oil pressure?
Old Jan 28, 2004 | 06:53 AM
More ?'s:
What all ECU's can work with my B16a1 OBD1 motor?
Also, will and ITR ECU be an OBD1? j/w
Old Jan 28, 2004 | 08:01 AM
Smith Wise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_B16CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">yea but, im going to chip mine so i'm not going stock vtec, and redline....but how low of a VTEC can i have without messing with my oil pressure?</TD></TR></TABLE>
Honda gave the del sol a 5500 rpm vtec engagement point for a reason...
Old Jan 28, 2004 | 09:29 AM
Katman's Avatar
More ?'s:
Well, this all depends on what you're going to do with your engine and the upgrades you're going to do, especially with your camshaft(s). So i can't say how a low of a vtec point is best.....actually its not a super good idea to make your vtec point lower than the stock vtec point, you'll actually wind up losing power, especially with stock cams. Whats your engine goal anyways ?
As far as which ecu will work with your engine, that all depends on what year your car. What year is your car?
If your civic is 92-95 its OBD1 equipped, so any US or JDM OBD1 B16A (P30)/GSR(P72) reprogramming suggested/ and reprogrammed P28 ecu's will & can power your B16A engine. There are a few other JDM OBD1 ecu's that aren't too popular that can be reprogrammed to DOHC VTEC spec as well (P91, P70, and a few others).
If your car is 88-91 its OBD (or OBD-0) equipped. The best ecu to use would be a PR3 or PW0 ecu to power the B16 engine, unless you've upgraded to OBD1...then of course you'd use an OBD1 ecu.
About OBD1 Type-R ECU's...
Honda of Japan never made an OBD1 version of any Type-R ecu, they're all OBD2 spec. The only thing remotely close to OBD1 about them is the programming on them; but the physical JDM Type-R ecu's are OBD2 spec.
Old Jan 28, 2004 | 09:52 AM
<U>Whats your engine goal anyways ?</U>
I have a few minor bolt-ons right now....EX. Power Plus intake mani, 4-1 type r header, etc. but i'm going to either go (Super charger) or im going to go all motor....which the all motor is most likely going to be the one i choose.....I;m looking to install a Hondata later on....and im looking for a CTR intake cam!!
What do you guys suggest....My main goal is lowering my E.T.'s
Old Jan 28, 2004 | 10:58 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_B16CIVIC &raquo;</TD></TR><TR><TD CLASS="quote"><U>Whats your engine goal anyways ?</U>
What do you guys suggest....My main goal is lowering my E.T.'s </TD></TR></TABLE>
EX what ? 96-98 EX or 92-95 EX?
Old Jan 28, 2004 | 11:30 AM
92-95 civic EX but i'm using a P30 ECU i believe out of a del sol
Old Jan 28, 2004 | 11:47 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MUGEN_B16CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">92-95 civic EX but i'm using a P30 ECU i believe out of a del sol</TD></TR></TABLE>
ok that helped.
If i were you, I'd just wait till you added the SC and use the Hondata when you get it, but leave the ecu stock for now. just my $.02
Old Jan 29, 2004 | 05:15 AM
ok, well im not sure what i'm going to do...
Dave Brabant
Jun 28, 2018 01:17 PM
ltrkstr2k
Jul 4, 2009 01:29 AM
the.hamburglar
Dec 27, 2005 07:24 PM
Snoppy
Oct 9, 2003 06:53 PM
nautica_t
Dec 4, 2002 02:18 PM
