HELP! ecu codes
i searched but couldnt find what i was looking for ..
b18a in crx
1 long flash 7 short flashes----17 right?
pause
4 long flashs 3 short---43?
but i didnt see any 43 listed on my ecu codes sheet? so am i not reading this right or ..what
thanks
b18a in crx
pause
thanks
well i ended up finding out what the hell code 43 is ... they're kinda like a code for the code.. and are not in the manual .. i had to do some research.. code 43 is primary O2 sensor.. 99% its bad gas.. and horrible weather.. just in case some one else is looking for this same problem .. i had to reply to it
Usually a code 43 is a sign of a bad O2 sensor. I'd say 90% of the time its a bad primary O2 sensor.
Code 17 is the vehicle speed sensor. Does your speedo work? If it does, get yourself a meter and run the tests here: http://www.we-todd-did-racing....3D%3D
notfastenough
Nov 11, 2004 04:31 PM
