jdm sir cluster in 90 crx dx?
Old Jan 27, 2004 | 10:12 AM
c for sea's Avatar
Default jdm sir cluster in 90 crx dx?
how do i go about making the cluster fit in my car since there is no electronic speed sensor? also, I'll be using my stock dx tranny w/ dohc zc turbo. thanks in advance.
Old Jan 27, 2004 | 07:48 PM
c for sea's Avatar
Default Re: jdm sir cluster in 90 crx dx? (c for sea)
bump
Old Jan 27, 2004 | 08:18 PM
XJamesX's Avatar
It phisically fits in like the USDM one. You will have to rewire it a bit. You will also need an electronic VSS from any 92 and up civic or 94 and up integra. wiring here.
http://b16a.honda-perf.org/cluster.html. To wire up the VSS just split the signal wire and run it into your ECU at pin B16 and then run it to the back of the cluster where the VSS signal goes. Then ground the ground wire and splice the power wire into a switched power source.
-James-
Old Jan 28, 2004 | 10:24 AM
c for sea's Avatar
thanks man. great response.
Old Feb 16, 2004 | 04:40 PM
EF-it's Avatar
Default Re: jdm sir cluster in 90 crx dx? (B18C5crx)
I got a EF9 cluster, and I'm having only one problem. Hooking up the VSS. You wrote that you have to splice the signal wire into pin B16, and than in the back of the cluster where the speedo signal goes. Isn't that the same wire(yel/red) just wondering if this is the correct info. If you can could you resopond with the pin number on the back of the cluster, just so I know for sure, and have you done this and it worked. I'm getting real pissed off with this thing, and just want to get it in and done. (I've already gotten all the rest of the pin outs for the cluster off of the page listed where you said to splice the wires) thanks.
Old Feb 25, 2004 | 07:04 AM
b18crx's Avatar
great post......
Old Mar 24, 2004 | 09:09 PM
c for sea's Avatar
Default Re: jdm sir cluster in 90 crx dx? (b18crx)
i got it all hooked up but how to i fix the tach signal i'm getting. if i turn the key to the 'on' position (so the lights on the cluster show but the car doesn't start), the needle for the tach will jump to about 800 rpm or so. when i'm idling, it'll be pretty much reading exactly that much more then what it really is.
ie: i have launch control on my car and it's set at 3.5k rpm. but on the cluster, it shows 4.5k rmp or so..
how do i take care of this? i'm using a pm6 if that matters. also, it's a dohc zc.
Old Mar 25, 2004 | 10:29 AM
RuthlessEF-9's Avatar
he said a DX not an Si will that tech still work ??
Old Mar 25, 2004 | 10:36 AM
c for sea's Avatar
i forgot to mention that.
yea, it's a dx rewired to mpfi for a zc.
I'm using the original ZC dizzy, chipped PM6.
Old Mar 26, 2004 | 11:08 AM
arent the gauge cluster wires different on a dx than an si
Old Mar 27, 2004 | 05:48 PM
c for sea's Avatar
si and dx cluster isw the exact same thing. please help.
Old Apr 9, 2004 | 12:56 PM
soundman's Avatar
maybe I am just stupid but I cant figure out that link in the other post so I have no idea how to wire that thing up... How do you get the door diagram working, and how do you know which pin to hook up where? Any help would be appriciated
Old Apr 9, 2004 | 02:01 PM
bryant's Avatar
Default Re: (c for sea)
If any of you want to sell your Cable Driven VSS. I would be glad to buy it
Old Apr 9, 2004 | 04:41 PM
90dxhatch's Avatar
Default Re: (Bryant)
it's posted everywhere how to get this cluster working and fitting, do a search. other wise use a el. vss out of a 92 and newer civic and the three wires on it go to power, ground and singal, as for the tach all 88-89 and 90-91 usdm cluster plugs are the same no matter if you have a si dx or std.
joe
Turbo Dan
20
Aug 5, 2008 09:46 PM
EF8IGHT
Feb 14, 2006 09:11 AM
I LOVE MY EF9
Jan 18, 2004 10:01 PM
solorexer
Sep 7, 2001 12:09 PM
