6th gen heating system won't turn off--
Old Jan 27, 2004 | 04:26 AM
angelovargas's Avatar
Default 6th gen heating system won't turn off--
Ok, it's the teens here in Northeast, but I don't want to turn on the heating system all the time.
At first I just thought that the engine is what's heating up the interior.
The climate controls are set to off, but the car is definitely heating on its own.
I don't remember the 6th gen having heated seats, but they seem to also generate it(I know I shouldn't complain, but just imagine next summer).
Tips, anyone?
Old Jan 27, 2004 | 05:47 AM
samaccord's Avatar
Default Re: 6th gen heating system won't turn off-- (r2N)
My gf's brother's 6th gen had a broken heater control valve a few months ago, maybe yours is stuck "open"? (His was stuck closed, and was leaking at the same time)
Old Jan 27, 2004 | 06:05 AM
JimBlake's Avatar
Default Re: 6th gen heating system won't turn off-- (samaccord)
Look at the plastic **** - pull it straight off, see if it's broken.
Our '98 broke the fan-speed ****. You turn the **** but it isn't turning the shaft. I suppose the temperature **** is just as easy to break?
Old Jan 27, 2004 | 06:13 AM
Default Re: 6th gen heating system won't turn off-- (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Look at the plastic **** - pull it straight off, see if it's broken.
How do I check if that's the problem? The temp **** does regulate heat or cold depending on the position, but how do I keep it off completely? It sound like a stupid question, but I didn't have this problem before. I have an 02 model.
Old Jan 27, 2004 | 07:31 AM
DrunkNRacer's Avatar
I have the same problem on my 5th Gen.. I turn the heater on (maybe once in a blue moon) and when I turn it off.. it still leaks out hot air from the vents. Its a retarded problem..
Old Jan 27, 2004 | 07:35 AM
jweller's Avatar
do you have automatic climate control or just regular old controls?
my **** broke as well. when you pull it off you'll see that the shaft has a flat spot on it. the corresponding flat spot on the **** had broken on mine. a little JB-Weld and it's as good as new.
the HVAC system will always move a little bit of air through the vents no matter what. it's to keep you from dying of CO poisoning.
Old Jan 27, 2004 | 02:41 PM
jwogen1's Avatar
Default Re: 6th gen heating system won't turn off-- (jweller)
yeah there is always a little air moving through the system, even if it is all the way in the off position you can still feel some warm air......not enough to really heat up the entire car though.
jaywoodz
Aug 2, 2007 04:49 AM
jdm_jeners
Oct 30, 2006 06:02 PM
Charri
Dec 9, 2004 10:49 PM
TurbothisLS
May 12, 2003 03:57 AM
Charlie Moua
Apr 24, 2003 04:41 AM
