Noob question alert! b16a2 tranny w/gsr block question
Old Jan 27, 2004 | 03:26 AM
Stock@$$GSR's Avatar
Default Noob question alert! b16a2 tranny w/gsr block question
'94 GSR block with a '99 B16A2 tranny
Here comes the noob question:
--Which clutch and flywheel do I buy for, the GSR or the B16A2?
I also assume that dumping in a Quaife diff for the B16A2 tranny and dumping in a LS 5th gear set is not going to cause any problems? Thanks in advance!
Old Jan 27, 2004 | 04:56 AM
Fobtions's Avatar
Default Re: Noob question alert! b16a2 tranny w/gsr block question (Stock@$$GSR)
flywheel= any B-series flywheel.
clutch pressure plate= any B-series
Clutch Disc= 93-up i think
just get a clutch set for a gsr integra to make things easier. HTH
Old Jan 27, 2004 | 01:51 PM
Default Re: Noob question alert! b16a2 tranny w/gsr block question (Fobtions)
THanks Fobtions
got another question tho... when replacing the b16a2 5th gear with the LS 5th, do I need anything else besides the LS 5th gear mainshaft and countershaft? Any gaskets or seals I need to replace?
Old Jan 27, 2004 | 02:02 PM
Fobtions's Avatar
you shouldnt need anything else for the swap
Hartattack
Jun 3, 2008 05:00 PM
trapstar101
Jun 8, 2007 09:19 AM
TeGGY_LS
May 16, 2004 10:36 AM
hatchattak
Feb 11, 2004 05:24 AM
