nitrous+ daily driver= good or bad
Old Jan 26, 2004 | 09:14 PM
sloweredcivic's Avatar
Default nitrous+ daily driver= good or bad
i was wondering if any one with personal experience could tell me if a zex setup on my car would be a good or bad idea with alll stock internals and how many sprays at how many horse i could probably sqeeze out of it. it is a d16z6 with a supposed 80k miles, any help woiuld be great thanks
Old Jan 26, 2004 | 09:29 PM
ls_vtec_crx's Avatar
Default Re: nitrous+ daily driver= good or bad (sloweredcivic)
my friend uses NOS on his daily driver and its minors....he has stock internals and i think hes doin a 70 shot...not too sure but its bigger than 50
the only thing is that ever since he got the car, his clutch has been goin a little its time for a new one
Old Jan 26, 2004 | 09:38 PM
ThatRicerDaniel's Avatar
Default Re: nitrous+ daily driver= good or bad (ls_vtec_crx)
its fine. do your timing, run 91 octane and keep your 2 degree colder plugs clean all the time and you'll be straight.
Old Jan 26, 2004 | 09:40 PM
91hob20hb's Avatar
same with my friends 91 rex si.he sprays 50 shot and it still runs good he's had it for almost a year now too.only thing is he has had problems with stock clutch not being able to handle the extra juice.so i would atleast recommend getting beffier clutch setup.so just as long as u dont abuse it will be fine. and i would stick with 50-70 tops until beffier internals are put in.
Old Jan 26, 2004 | 09:59 PM
Bleed Black's Avatar
Default Re: (91hob20hb)
Its all relative. Some people have horror stories while others have excellent results. Depends on how you use it and how the motor handles it. Its pretty much a gamble and a decision you should make on your own. I personally never had any negative results with my ZEX kit on my D16z6...but I spent the money on a clutch and made sure I had fuel at all times and always checked everything before and after I sprayed. I guess its all in HOW you use it. Responsibly or not.
Old Jan 26, 2004 | 10:08 PM
91sihatchback
Guest
Posts: n/a
dude no offense to my ef homies but nos is weak, for every 1 good story i hear 10 bad ones so i think you might wanna re-think everything before you do this...nos is a cheap cheating way to make your car faster and i hate it! anyways everyone knows n-a is better!!! haha....
Old Jan 26, 2004 | 10:28 PM
second edition's Avatar
Default Re: (91sihatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sihatchback &raquo;</TD></TR><TR><TD CLASS="quote">dude no offense to my ef homies but nos is weak, for every 1 good story i hear 10 bad ones so i think you might wanna re-think everything before you do this...nos is a cheap cheating way to make your car faster and i hate it! anyways everyone knows n-a is better!!! haha....</TD></TR></TABLE>
ok..........
Old Jan 27, 2004 | 07:17 AM
KoRE's Avatar
Default Re: (slowasshatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowasshatch &raquo;</TD></TR><TR><TD CLASS="quote">Its all relative. Some people have horror stories while others have excellent results. Depends on how you use it and how the motor handles it. Its pretty much a gamble and a decision you should make on your own. I personally never had any negative results with my ZEX kit on my D16z6...but I spent the money on a clutch and made sure I had fuel at all times and always checked everything before and after I sprayed. I guess its all in HOW you use it. Responsibly or not.</TD></TR></TABLE>
This is the best advice you will ever recieve...
Nitrous can be safe and reliable but it depends all on the user. I had nitrous on my auto 97 integra LS, this was a couple years ago and i was irresponisble and used it ALOT like every light not every light but ALOT and that was on a 75 shot
, i eventually blew my head gasket... but i also have friends who spray and their A-OK and they have been spraying for a while
So just be smart about it and don't push it all the time and you should be good 50 shot is very safe IMO
Old Jan 27, 2004 | 07:21 AM
BTLFED's Avatar
Umm...right
I ran an 80 shot of nitrous on my ZC forever and the only problem I had was I melted a valve because I had a bad injector. Stupid me for not checking them
Nitrous is perfectly safe if you take the necessary precautions to run it. Anyone can half *** a nitrous install, and usually those are the people that brake things....like I did.
civicmike2000
May 8, 2004 12:09 PM
matix
Oct 26, 2003 01:26 PM
redteg1
Dec 5, 2001 08:14 PM
91lude
Nov 3, 2001 01:53 PM
