Difference: RS vs. ITR axles
I am currently running a set of 97 ITR axles (reman from napa)
Part number 8000 for one of them :-)
Anyhow, I was doing some reasearch & saw the part numbers are close but different. I am assuming its because of abs/model.
Left (drive shaft set)
97 ITR - 44011 st7 r50
97 ls - 44011 s04 j51
97 rs - 44011 s04 j01
What is the actuall difference in the axles besides abs if any ?
rs = non abs axle
ls = abs axle ( you have a clip on the axle so the abs sensor can work
itr = abs + I think i gets heavy duty joints but not sure about that....( the ls axle will fit perfectly on the R btw...
onesecplz
Dec 21, 2003 06:56 AM
xrtdac
Nov 7, 2003 10:27 AM
