YAY!...got some parts in...Thanks Ron, and Kyle!...
Old Jan 26, 2004 | 08:05 PM
*Boostwerks*'s Avatar
Default YAY!...got some parts in...Thanks Ron, and Kyle!...
This is Ron's JBE sheetmetal intake manifold. I just hope it fits into my tiny CRX engine bay... Thanks so much Ron for the killer deal!
And I also got my new Action 2MS clutch from Wired Speed! I should have my ACT streetlite flywheel here tommarow.
I can't wait to see what these can do on the GSR setup!
Old Jan 26, 2004 | 09:22 PM
FredoSP's Avatar
Default Re: YAY!...got some parts in...Thanks Ron, and Kyle!... (Bryson)
i got the same clutch
Old Jan 26, 2004 | 11:20 PM
Smokinsax's Avatar
The Boot
yeah...those runners are long! hope it works out for you.
Old Jan 27, 2004 | 01:10 PM
Anyone use the Action dual diaphram pressure plate with a cable tranny?
just kinda wonderin how it's gonna feel.
Old Jan 27, 2004 | 01:37 PM
Got the ACT Streetlite in today!
Old Jan 27, 2004 | 02:46 PM
Kataku2K3's Avatar
Yea, those runners look really long... From the looks of the base you're running a P72 cylinder head which is fine it's just that B series motors make it even that much more tight... Scott and I have been working on Will's Rex's FI setup for the past few months and even with the Edelbrock Victor X IN manifold (with shorter runners and a bigger plenum) it's a squeeze... Not necessarily to the firewall but more just the throttle body running into your stock fuel lines, etc... If you're running stainless line forward then it's really not that big of a deal... I don't have any good pics of higher up on his engine bay (I'll wait till we finish) but you can kind of see how close the fuel lines are to the TB (actually they rub )... Looks good tho
Old Jan 27, 2004 | 03:07 PM
MONTCO Si's Avatar
Default Re: YAY!...got some parts in...Thanks Ron, and Kyle!... (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">i got the same clutch </TD></TR></TABLE>
also intrested in how the action dual diaphram clutch is going to feel. ill be installing one in my b16 during my buid. any low speed chatter? is it a very aggressive?
Old Jan 27, 2004 | 04:06 PM
yellowhonda88's Avatar
Default Re: YAY!...got some parts in...Thanks Ron, and Kyle!... (MONTCOSi)
WOW, you are my hero.....lol....I am building almost the same setup. Yellow CRX, B series motor, but I didnt think i could get a Full-Race kit to fit, so i didnt try. I went with MaxRev. But, I haven't worked on it in awhile nor have i finished it. If I have any random questions, I hope you dont mind if I email you. That rex looks sweet.
Brett
Old Jan 27, 2004 | 04:20 PM
grndcont's Avatar
ya, i have that same clutch too, with the dual diapram. it's not unstreetable by far, with good engagement for a 6-puck. w/barly any chatter, althow i think i did just brake my first axcel with it.
Old Jan 27, 2004 | 04:52 PM
Ri5e's Avatar
Default Re: (grndcont)
Long runners. All motor perhaps?
Old Jan 27, 2004 | 05:23 PM
xenocron's Avatar
Default Re: (BG Boost)
Long runners & small plenum good for NA
Short Runner & large plenum good for Boost
Are these two statements true or false?
Old Jan 27, 2004 | 08:25 PM
1point5CRX's Avatar
Default Re: (jerseykid609)
pretty badass
Old Jan 27, 2004 | 09:05 PM
FORDS- SUCK!!!!'s Avatar
Default Re: (1point5CRX)
i HERD That clutch and flywheels is for ******\ Good luck Wiredspeedlab a reputable business for import parts what a change
Old Jan 27, 2004 | 10:03 PM
Default Re: YAY!...got some parts in...Thanks Ron, and Kyle!... (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Yea, those runners look really long... From the looks of the base you're running a P72 cylinder head which is fine it's just that B series motors make it even that much more tight... Scott and I have been working on Will's Rex's FI setup for the past few months and even with the Edelbrock Victor X IN manifold (with shorter runners and a bigger plenum) it's a squeeze... Not necessarily to the firewall but more just the throttle body running into your stock fuel lines, etc... If you're running stainless line forward then it's really not that big of a deal... I don't have any good pics of higher up on his engine bay (I'll wait till we finish) but you can kind of see how close the fuel lines are to the TB (actually they rub )... Looks good tho
heheh...yah.
From initial measurements we've made, it looks like it should have 2" of clearance from the firewall. I will also be using Ron's BBK mustang TB, along with a custom ss fuel line setup, so that clearance should be ok.
And about the runner length...Ron has gone mid 10's with this manifold...and thats all I need to know!
Teamdiesel
36
Mar 27, 2010 03:14 PM
jjaskula1
Jan 24, 2006 06:53 PM
Nextelbuddy
12
Jan 6, 2004 05:12 PM
TurboBumblBee
Jan 5, 2004 07:09 PM
HX_Guy
Aug 29, 2001 09:09 AM
