Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside
Old Jan 26, 2004 | 04:58 PM
tunedbylorange.com's Avatar
Default Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside
Finally got a chance to dyno the car with the Golden Eagle manifold, just got back a few minutes ago.
Dennis set the boost at 9 psi on the first run with the new manifold and made 281 on the first pull, with no dyno tuning - only street tuning.
Before the Golden Eagle Intake manifold was installed (with the boost set at 10 psi) it made a best of 274 whp
On the second pull he turned up the boost to 12 psi and put down 314 to the wheels.
Next we plan on hitting up the 1/4 and then finally Dennis will build the motor, maybe!!!!!
sorry for the edit , had to add pics
In the third pic Dennis is inspecting the motor to see if any rods are hanging out of the block after putting down 314 whp.
Yup, everything was still intact
Modified by tunedbylorange.com at 11:36 PM 1/27/2004
Old Jan 26, 2004 | 05:23 PM
SpdFrk's Avatar
Default Re: Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside (tunedbylorange.com)
Nice numbers.
Whats your complete setup?
Old Jan 26, 2004 | 06:13 PM
ProEater's Avatar
Default Re: Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside (SpdFrk)
314hp at 4k? then it falls off.....? im confused
Old Jan 26, 2004 | 06:23 PM
boosted92's Avatar
Default Re: Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside (ProEater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProEater &raquo;</TD></TR><TR><TD CLASS="quote">314hp at 4k? then it falls off.....? im confused</TD></TR></TABLE>
Psst, that's the torque line!
Old Jan 26, 2004 | 07:06 PM
J.R.'s Avatar
Default Re: Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside (boosted92)
nice numbers...get that thing back to the track now
Old Jan 26, 2004 | 07:09 PM
HXMan's Avatar
wow..seems like it holds the TQ real nice.
Old Jan 26, 2004 | 07:27 PM
satan_srv's Avatar
Default Re: Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside (HXMan)
12 psi on a stock block? Be careful dude! I pity your ringlands!
Old Jan 26, 2004 | 07:28 PM
Suprdave's Avatar
Default Re: Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside (satan_srv)
B-series can handle it better than H22a.
Old Jan 26, 2004 | 08:02 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">12 psi on a stock block? Be careful dude! I pity your ringlands!</TD></TR></TABLE>
brian seems to be pulling it off quite well. but he tunes it himself all the time.
Old Jan 26, 2004 | 08:25 PM
p3s7's Avatar
do you have an afr graph too? just curious to see what it looks like..
Old Jan 26, 2004 | 08:26 PM
accordfreak's Avatar
Default Re: Golden Eagle H22 Intake manifold..... 314 whp.....dyno inside (shakes)
any pix of the new manifold?
Old Jan 26, 2004 | 10:29 PM
H22aInside's Avatar
u say its in a cx. what kind of clearnce issues, if any did u have with the manifold. and what kind of mount kit was used. thx
Old Jan 27, 2004 | 07:29 AM
H22A EG6's Avatar
Default Re: (H22aInside)
that is a bad **** ineed that for my cx whats ur set up?
Old Jan 27, 2004 | 08:00 AM
Jason kiDD's Avatar
I am glad you guys are taking your time. Great numbers and killer torque.. Keep us updated on the progress, I may be heading down that very same path soon...
Old Jan 27, 2004 | 12:48 PM
Default Re: (p3s7)
don't have any graphs of the afr but Dennis has it set to 11.9 to 12.0 all the way across
no clearance issues, Hasport Mounts - only the best!!
Heres the set up
http://www.tunedbylorange.com/shopcar.html
Old Jan 27, 2004 | 12:55 PM
ProEater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
Psst, that's the torque line!</TD></TR></TABLE>
its all so clear to me now
Old Jan 27, 2004 | 12:56 PM
X-Mazda 3 Racer's Avatar
Default Re: (tunedbylorange.com)
Hey, We are extremely pleased with this post. The car looks great and we are glad our products are working good for you. Keep us updated on your progress.
Golden Eagle Mfg.
Old Jan 27, 2004 | 01:26 PM
Default Re: (GoldenEagleMfg.com)
Thx, soon we'll be sending you guys the block to get resleeved after we run the 1/4
Will be able to get the new HD sleeves??
Old Jan 27, 2004 | 01:31 PM
Yes, our HD sleeves have replaced the Goldzilla sleeve. We will keep an eye out for your block when you are ready. Keep up the good work
Old Jan 27, 2004 | 01:34 PM
sweet
MikeySpec
Nov 12, 2011 02:37 PM
kamAccord
May 20, 2005 05:30 PM
PrecisionH23a
Sep 15, 2004 11:21 PM
