TURBO accords! with f22 blocks.. THE PLUG above the oil filter for pressure????
Old Jan 26, 2004 | 03:44 PM
accordfreak's Avatar
Default TURBO accords! with f22 blocks.. THE PLUG above the oil filter for pressure????
okay i was looking around at my spare blocks and was trying to find any plugs that can be used as oil pressure for my oil pressure gauge. I don't want to tap it in with the turbo oil feed where the stock oil pressure sensor is at as I am afraid the vibration might break the fitting off.
so has anybody tried this port for oil pressure? i unscrewed it and it leads straight down to the passage way for the oil filter.
Old Jan 26, 2004 | 04:02 PM
Accord94DX's Avatar
Default Re: TURBO accords! with f22 blocks.. THE PLUG above the oil filter for pressure???? (accordfreak)
prolly would work fine. I use a GE sammich. what kind fitting is that
Old Jan 26, 2004 | 04:17 PM
poid's Avatar
very, very interesting...i might have to investigate that port, as i need to hook up my oil pressure gauge in the next couple of days
Old Jan 26, 2004 | 04:40 PM
stinker504's Avatar
You can safely use the oil pressure sensor if done correctly.
http://www.theoldone.com/articles/oilpressure/
Old Jan 26, 2004 | 05:12 PM
Conechaser's Avatar
Default Re: (stinker504)
My oil pressurge guage is hooked up like in the 1st pic in that link. Been that way for a little over 6months now w/ no problems. *knocks on wood*
Old Jan 26, 2004 | 06:15 PM
Default Re: (94Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Accord &raquo;</TD></TR><TR><TD CLASS="quote">My oil pressurge guage is hooked up like in the 1st pic in that link. Been that way for a little over 6months now w/ no problems. *knocks on wood*</TD></TR></TABLE>
yes mine too but i also want to hook up an oil pressure gauge.. i want to put as much less weight on the adapter as possible.
hmm i guess i'll try it that hole out since it's only for an oil pressure gauge... gotta find the fitting size now..
Old Jan 26, 2004 | 06:28 PM
Legendaryyaj's Avatar
Default Re: (accordfreak)
Is that for a mechanical or electrical gauge? Is the electrical worth the extra $100 for ease of install?
Old Jan 26, 2004 | 06:31 PM
poid's Avatar
electrical is worth the extra just so you dont have an oil line fed into the cabin...imagine if that thing springs a leak
Old Jan 26, 2004 | 07:32 PM
fknslmd's Avatar
Default Re: (Legendaryyaj)
if you find the fitting for that port and it all works out let me know because ill be hooking all my **** up here next month sometime.(boosted f22)
Old Jan 27, 2004 | 02:38 AM
poid's Avatar
ahhh screw it, no way in hell i could see it with the engine still in the car
Just used the stock pressure sensor location, line to the block and the Greddy sensor screwed on there. Easy enough (even if i didnt have the right tools for the job!)
Old Jan 27, 2004 | 12:50 PM
Default Re: (poid)
use a mirror to see it hehe
Old Jan 27, 2004 | 12:52 PM
ForceThis!'s Avatar
Default Re: TURBO accords! with f22 blocks.. THE PLUG above the oil filter for pressure???? (Accord94DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX &raquo;</TD></TR><TR><TD CLASS="quote"> I use a GE sammich. </TD></TR></TABLE>
yep. me too
xkrazyxjbrkerx75
Aug 9, 2011 02:47 PM
hotshot100
Apr 14, 2010 05:10 PM
hondaeg8
Jul 28, 2005 05:10 AM
hondapwr
Mar 11, 2004 02:43 PM
accordfreak
Jan 26, 2004 06:14 PM
