will my mugen chipped ecu blow my drag turbo'd b16 up?
Yes. Reason being is MUGEN chips their ecu's for NA set-ups which require more aggressively advanced ignition timing. With turbo you usually want to retard your ignition .75 degrees per psi of boost. You also have to understand with turbo you will need a lot more fuel then a NA car desires.
Sell the MUGEN ecu and invest in either a s-afc or better yet a nice EMS.
ignition advance is askin for trouble- sell it and look for alternative tuning....mmmmhondata...if u got the money that is- if not go with a hack setup w/ safc
douglas_be
Mar 24, 2004 09:18 PM
WAFFLES
Dec 18, 2002 03:29 PM
