Have to apply gas to start car when its cold out, any suggestions?
Old Jan 26, 2004 | 01:54 PM
G2turbo_terror's Avatar
Default Have to apply gas to start car when its cold out, any suggestions?
When its around zero degrees out my car will start but run for a second and die as if its running off of fumes (When its around 15 degrees or so it'll start fine on its own) it'll continue to do this untill I apply a little bit of gas and then it fires right up. What I've done lately is prime the fuel pump, push the accelarator a little, then crank it and it starts up fine but I'm worried I might have low fuel pressure. My tank is holding pressure fine because I can hear it escape when I take the gas cap off. Any ideas would be helpful. TIA
The Car; 1990 civic std, 155K. MPFI swap performed in may and a used gas tank installed last Feb. otherwise I just installed a new fuel filter and it has newer ignition parts. It also has a gutted cat and the timing is set to stock.
still4punk
Apr 26, 2011 03:00 PM
dan89crxsi
16
Sep 24, 2006 01:22 PM
DC2point0
13
Jul 24, 2005 06:02 PM
Sergei01
Apr 12, 2004 11:30 PM
Lost Type R
Aug 25, 2003 09:25 PM
