?'s for my b18b turbo set-up
First of all I'm doing the usual. Golden eagle sleeved the block and bored it to 84mm. Wiseco pistons, cuz I work there, eagle h beams.......question is will ls pumps be good enough to support 400whp? Should I run a block girdle? If so, do I need to run vtec main bolts because they're longer to accomodate the girdle? Suggestions for cams would be nice too. Thanks. Ry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 »</TD></TR><TR><TD CLASS="quote">First of all I'm doing the usual. Golden eagle sleeved the block and bored it to 84mm. Wiseco pistons, cuz I work there, eagle h beams.......question is will ls pumps be good enough to support 400whp? Should I run a block girdle? If so, do I need to run vtec main bolts because they're longer to accomodate the girdle? Suggestions for cams would be nice too. Thanks. Ry</TD></TR></TABLE>
get a new fuel pump. (ex walbro 255lph)
lots of people are using stock block girdle.
as for cams, i personally woulnt worry about it. instead of spending mooney on
cams and such, i would rather spend it on better pistons/rod combo.
and then just turn up the boost.
http://www.autoperformanceengineering.com - walbro's from $85!
I was talking about oil/water pumps not fuel pumps. I already have walbro 255. b18bek, stop ******* everyone you ******. I don't live on this web site so I wouldn't see what was on LAST WEEK! nOT EVERYONE KNOWS HOW TO PUT A GOOD MOTOR TOGETHER AND NEEDS SOME ADVICE. "If you're not going to say something nice don't say anything deutch!"
