Car fogs up fast
Old Jan 26, 2004 | 12:08 PM
SFrogue85's Avatar
Default Car fogs up fast
Are there nay ways to keep my 1995 Honda Civic EX from not fogging up so much. Obviously the defroster and stuff, but that doesn't seem to work. i usually have to clear it with A/C. Is this a common problem and what can I do so it doesn't happen?
Old Jan 26, 2004 | 12:10 PM
Ricey McRicerton's Avatar
Default Re: Car fogs up fast (SFrogue85)
Make sure the windows are clean. Sounds like a stupid suggestion, but having very clean windows helps quite a bit. I wonder if you can put the anti-fog stuff from scuba diving lenses on it??
FrostySol's Avatar
stop breathing? Nah, you could try some of that no-fog stuff from like autozone and places, but I've heard mixed opinions on it. If it's real bad just crack a window until the defogger can get a chance to do it's job
Old Jan 26, 2004 | 12:15 PM
dustinsterk's Avatar
Here is a simple fact suprisingly some people do not know. In the summertime when you use the A/C set the climate control to use the inside (circulating air). In the winter time, when using the heat, set the climate control to use the outside (fresh) air. If you use the circulating air in the winter, yes the car heats up quicker....but fogs the hell out of the car.
Old Jan 26, 2004 | 12:16 PM
Buzzbomb's Avatar
Make sure your Fresh Air button is on and not the Recirculation button.
Old Jan 26, 2004 | 12:24 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Car fogs up fast (Buzzbomb)
stop banging chicks in your car. problem solved.
Old Jan 26, 2004 | 01:45 PM
Xander teh Grate!'s Avatar
Default Re: Car fogs up fast (boostincoupe)
My parent's grand prix does this really bad also. There's has an air leak though and that's probably is what's causing it. Have you checked for leaks or your weather stripping?
Old Jan 26, 2004 | 02:32 PM
redlinetuning's Avatar
Default Re: Car fogs up fast (Wish_I_Was_Fast)
RainX makes a good de-fogger called FogX..
there's threads out there.. search for RainX or FogX
Old Jan 26, 2004 | 03:05 PM
nonsense's Avatar
clean the windows really well . . . . and use the AC when you're running the defogger. It dries out the air so there's less fogging.
Old Jan 26, 2004 | 03:12 PM
HATCHingMN's Avatar
bring a towel along next time
Old Jan 26, 2004 | 03:36 PM
pdiggitydogg's Avatar
I have an inside-chamois that I use to de-fog the windows (when I dont use ac)
Also, if it doesnt freeze where you are, try the rainX anti-fog wipes....but if it freezes it just makes it a hell of a lot worse w/ frozen rainX chemicals instead
Old Feb 3, 2004 | 11:57 AM
SFrogue85's Avatar
I tried out just using the outside air and I have had no problems with fogging since.
Old Feb 3, 2004 | 12:08 PM
B16Drag's Avatar
How many HT posts does it take to defog a window?
Old Feb 3, 2004 | 12:20 PM
elevatethis's Avatar
Default Re: (B16Drag)
The anti-fog that rainx makes works great, but I can only use it on my windshield since all my others are tinted
Old Feb 3, 2004 | 12:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Drag &raquo;</TD></TR><TR><TD CLASS="quote">How many HT posts does it take to defog a window? </TD></TR></TABLE>
Seriously. I already told him to stop banging chicks in his car, you'd think he got it by now.
Old Feb 3, 2004 | 12:43 PM
Matty.'s Avatar
FOG-X.
Old Feb 3, 2004 | 12:54 PM
GRAVEDIGGER's Avatar
Default Re: Car fogs up fast (nonsense)
any leaks in the car? sounds like a moisture problem
FTNW
May 31, 2011 08:59 PM
crazykrn
Oct 29, 2010 04:55 PM
Nonio
Sep 24, 2010 03:10 AM
D16Z6_turbo
Oct 5, 2007 11:05 PM
Origin
Oct 15, 2003 09:59 PM
