Rebuilding a front suspension on a 1991 Honda Civic DX 3dr hatchback
This summer I plan to replace the original struts and CV joint boots on my Civic that has 180,000 easy miles. This is a one owner car that has been well maintained. I am only interested in maintaining stock ride and in increasing the usable life of the Civic; I am not interested in a "performance" suspension.
1) Is there any difference between Japanese made ball joints and the ball joints for this car sold under the Moog/TRW brand
2) Why is it impossible to purchase an upper ball joint for this car; the complete A arm with the ball joint can be purchased but not the ball joint alone
3) Since I can detect no unusual noise from, i.e. the front wheel bearings, inner and outer CJ joints are quiet, can I simply clean them thoroughly and regrease with the appropriate lubricant. i.e. is there are logical reason to replace the bearings or joints?
4) Since I must completely disassemble the front suspension. should I take the opportunity to replace all the rubber bushings (upper and lower A arms, radius rods stabilizer end bushing and sway bars)?
5) Ditto on the upper and lower ball joints and tie rod ends?
5) The shop manual recommends a "high quality molydenum grease" to repack the CV joints. Can that grease also be used for the wheel bearings?
Dennis Waller
Dennis Waller
dazebreak
Jan 30, 2013 07:25 PM
DennisWaller
Jan 27, 2004 04:44 PM
