LS/VTEC Question
I want to build a LS/VTEC motor to with stand 8000 rpm. What will be needed for that. I am running PR3 pistons on a B16A2 head.
I also want to purchase Toda Cams for this. Is my valve train going to live after I hit Vtec with these cams in a LS/VTEC with PR3 pistons?
ok at the least you will need arp rod bolts and your rods shot-peined for the bottom end. A b16a or b18c oil and water pump. Yeah your valvetrain will long if you upgrade it to the specs of what series todas you get.
