Throttle Body Spacers??
Old Jan 26, 2004 | 09:31 AM
leftbehind33's Avatar
Default Throttle Body Spacers??
Hey, i was just browsing thru ebay and came across some throttle body spacers, but the add failed to explain how they work. By looking at it, the in side of the bore has lines diagonally cut. I'm guessing that this induces some kinda of vortex flow or something. Is that what it does? Does it really help your performance?
Old Jan 26, 2004 | 09:55 AM
JimmyAtlantis's Avatar
Default Re: Throttle Body Spacers?? (leftbehind33)
bump for good question
Old Jan 26, 2004 | 10:16 AM
ProEater's Avatar
Default Re: Throttle Body Spacers?? (JRI94)
ive heard a little bit about these but i want to know the details of it
Old Jan 26, 2004 | 10:19 AM
pdiggitydogg's Avatar
https://honda-tech.com/zerothread?id=745031
spoon ventuli plate would work better
Old Jan 26, 2004 | 10:56 AM
thrty8street's Avatar
Default Re: (pdiggitydogg)
one time i was watching HORSEPOWER TV and they put one on a mustang v8 and dynoed it. they actually lost like 5whp from it. imagine what it could do to an i-4.
Old Jan 26, 2004 | 10:58 AM
FrostySol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">spoon ventuli plate would work better</TD></TR></TABLE>
what he said
Old Jan 26, 2004 | 11:34 AM
suspendedHatch's Avatar
Default Re: (FrostySol)
I put a TRD one on my friend's truck. Installation was insanely easy. He had an Injen intake. I'm skeptical about this kind of thing but its TRD. I was told that a spacer will move the power down in the RPM band, which is good, but it's not so much adding power. That's like what you would do with a cam gear. Anyway, it makes this woosh sound right when you tip in to the throttle, its a very satisfying sound, almost like a turbo but coming in at the opposite time. His exhaust sounds a little more serious on acceleration, but he said he didn't notice much difference in power.
I suggest only getting it if it is some serious name brand stuff. Then install at the dyno so you can do before/after pulls for all of us.
Old Jan 26, 2004 | 11:40 AM
staticchmbr's Avatar
i bought one a while ago at a car show for my 00 civic si. i did feel a bit of power from it, but not too much. i also noticed that my gas mileage went up..but again, not too much. it did make a cool whooshing sound too. if you get one, i wouldnt pay too much. i got mine for like 40 bucks. its supposed to make a vortex in your throttlebody, and increase the volume of air going into your intake manifold. unfortunately, i didnt get it dynoed with it on, and then i got a bigger throttlebody, and skunk2 IM, so i dont have it on anymore. darn thing wont fit.
Old Jan 26, 2004 | 02:20 PM
vtekstorm's Avatar
Default Re: Throttle Body Spacers?? (staticchmbr)
o that stupid throttlebody spacer. that thing was a joke. i installed one on a 98 dx. it just bad a cool whistle sound kinda like a blow off valve for a turbo. i think that thing is a waste of money. the install was real ez. but its not worth the money. what it supposed to do is speed up the airflow as it enters the into the throttle thats y its shaped liked a helix coil.
Old Jan 26, 2004 | 04:33 PM
Default Re: Throttle Body Spacers?? (vtekstorm)
thanx guys, $40 isn't worth a cool swooshing sound. this site rocks!!!
Old Jan 26, 2004 | 05:03 PM
Sliced Beard's Avatar
summit racing sells this one for 105 dollars
they clain that it increases atomization and speed up th free flowing air
they say it adds horespower
Old Jan 26, 2004 | 05:19 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=745031
ok from what i have read on that thread this thing would work wonders on a wet nitrous set up if it helps atomize the mixture what do u experts think about that
Old Jan 26, 2004 | 08:28 PM
bushfreakz's Avatar
hey if it gets you better gas mileage and doesnt hurt your performance its worth 40
not that 40 wouldnt be better somewhere else...
Old Jan 27, 2004 | 03:25 PM
if you want a spoon Ventuli plate http://www.randdmotorsports.com has one in stock
give them a call and ask how much it is
tell them that daniel sent you
Old Jan 27, 2004 | 03:45 PM
sillvercivicgsr's Avatar
i had one on my '97 4door i put it on the dyno w/ and w/o it. saw about a 2 hp increase and 7ft. lbs. of torque increase
Old Jan 27, 2004 | 04:04 PM
NonovUrbizniz's Avatar
Loved
Info is pretty much all here...
Considering it MAY give about 2hp I'd say it EASILY worth the 40 bucks... An intake barely makes 2-7 hp and costs over 100...
I wish someone would make one like the spoon venturi but out of "phenolic" so it prevents heatsoak... (and I know they have the ceramic coated one's but phenolic is MUCH better at preventing heat transfer).
AllSpedup04
Sep 27, 2005 08:19 PM
mintscorpion
28
Jun 30, 2005 08:25 PM
race teg
Jan 12, 2003 07:56 PM
EGsex
Dec 10, 2002 03:49 PM
57one
Oct 16, 2002 01:22 PM
