greddy turbo kit ?
Old Jan 25, 2004 | 08:14 PM
onelowchef's Avatar
Default greddy turbo kit ?
i have a 99 civic ex and trying to get a turbo kit and the prices. would a 92-95 kit work on my car?
Old Jan 25, 2004 | 08:30 PM
b16ahybrid's Avatar
Default Re: greddy turbo kit ? (onelowchef)
yeah the kit would bolt up.
Expect to pay about $1200 - $1500
Old Jan 25, 2004 | 08:33 PM
onelowchef's Avatar
Default Re: greddy turbo kit ? (b16ahybrid)
would the kit work properly, or would i have to rigg it?
Old Jan 25, 2004 | 08:35 PM
Cruiser G's Avatar
it works, but the piping is a little off. It works fine though.
Old Jan 25, 2004 | 08:38 PM
onelowchef's Avatar
Default Re: greddy turbo kit ? (Cruiser G)
is that what you run on your civic in your avatar?
mrod006's Avatar
yup. i have the 92-95 kit with a 99-00 si intercooler. just needed to reweld a charge pipe. that's all i needed to make it work.
Old Jan 25, 2004 | 09:06 PM
TurboTony's Avatar
Default Re: greddy turbo kit ? (mrod006)
Greddy kits suck just do another kit. Better numbers and power which means you will be happyer with it.
Old Jan 25, 2004 | 09:10 PM
onelowchef's Avatar
Default Re: greddy turbo kit ? (TurboTony)
i ve heard greddy kits work really will on d series setups and they are fairly priced.
Old Jan 25, 2004 | 09:17 PM
TurboTony's Avatar
You might be right but I know on the B-Series they are not that great. Because my boosted LS Integra puts out more then my friends and my time is a 13.9 and his is a 14.8 and mine puts out more whp and a better track time then my friends turboed gsr with that kit. Yes, the price is a good price for a turbo kit even and you can find all the extras pretty cheap.
Old Jan 25, 2004 | 09:49 PM
gtfourmn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTony &raquo;</TD></TR><TR><TD CLASS="quote">You might be right but I know on the B-Series they are not that great. Because my boosted LS Integra puts out more then my friends and my time is a 13.9 and his is a 14.8 and mine puts out more whp and a better track time then my friends turboed gsr with that kit. Yes, the price is a good price for a turbo kit even and you can find all the extras pretty cheap.</TD></TR></TABLE>
Your friend needs to learn how to drive.
Old Jan 25, 2004 | 09:55 PM
TurboTony's Avatar
Default Re: greddy turbo kit ? (turbine)
That maybe true but explain this the small turbo, internal wastegate, and the cast mainifold. Which means you can not boost more then like 8psi and it is hard to upgrade.
Old Jan 26, 2004 | 01:15 PM
Spoolin18's Avatar
What do you mean you can't boost over 8 psi? Buy a damn boost controller and bypass the wastegate.....very very simple. Another thing...with that turbo being so small he should walk you in the quarter with it being fully spooled around 2800 RPMS. He really does need to learn how to drive.
Old Jan 26, 2004 | 01:27 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onelowchef &raquo;</TD></TR><TR><TD CLASS="quote">i have a 99 civic ex and trying to get a turbo kit and the prices. would a 92-95 kit work on my car?</TD></TR></TABLE>
the 92-95 kit works.
only thing is the placement of the first o2 sensor is farther up to the front bumper. just get an o2 extender or extend the wires of your o2 sensor by soldering it.
other than that it works fine
Old Jan 26, 2004 | 01:28 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTony &raquo;</TD></TR><TR><TD CLASS="quote">Greddy kits suck just do another kit. Better numbers and power which means you will be happyer with it.</TD></TR></TABLE>
Dude you ran a 13.9 at 10 psi on a LS.
Kill yourself before you make ignorant comments like that stunnA.
Old Jan 26, 2004 | 01:48 PM
kranked91dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTony &raquo;</TD></TR><TR><TD CLASS="quote">That maybe true but explain this the small turbo, internal wastegate, and the cast mainifold. Which means you can not boost more then like 8psi and it is hard to upgrade. </TD></TR></TABLE>
Greddy kit is one of the best bang for the buck's for D series boost bolt one. Shure you can do your own kit, even if you have a B we don't give a **** this is out of topic, next time noob's STFU. This guy's want to know if the Greddy kit worth the shot.
YES i know cause I actually own one.
the kit is pretty good, the blue box suck dick, but the turbo is a great unit, pipe are already bent and ready to bolt on, everything fit like a glove.
Go for it.
you can easily obtain 200 whp on a boosted D series with the greddy kit and a bit of tuning.
see ya
Kranked.
Old Jan 26, 2004 | 01:55 PM
onelowchef's Avatar
why does the blue box suck so bad and would a vafc replace what it does.
Old Jan 26, 2004 | 02:16 PM
Default Re: (onelowchef)
On the blue box, to learn about it you'll have to search like a Big boy now...
in large, it suck because of the limited tunability that you got ( the blue box will make you run RICH as **** ) you'll have to retard timming a few degrees before enjoying the kit to it's full potential, get some NGk RBK7E plug, they are colder and will help in preventing detonation too....
if you can get a stand alone go for it... I still prefer the blue box to the FMU setup the FMU ( or any rising rate regulator ) will pump up static fuel pressure, in fact Flow is important in to delivering enough fuel to you engine, The blue box do the right thing's the only major prob's with it, it's that it dosn't allow us to tune it to runn more boost ( stable up to 8 psi with blue box ) the new kit however will came in with a preprog E-manage, so if you plan to buy new, man, you will be more than happy with the e-manage cause it's a programable unit, not the best, even very far of the best but still a programable controler that allow you to do what you want to do with your engine, even blow the **** out of it ( * sarcasm * )
use the search buddy, there is plenty of info on this site, more that you can probably ingest.
Kranked
Old Jan 26, 2004 | 02:22 PM
This One's Avatar
Default Re: (kranked91dx)
I have a greedy sohc kit, but only the turbo, manifold, and downpie i would be willing to sell that way you can have some moeny to use whatever Elecltronics you want
Old Jan 26, 2004 | 02:33 PM
hadboosttroy's Avatar
its not that small of a turbo, and the manifold and internal wastegates are FINE. cant boost more than 8 psi? are you on crack? cause dsm guys dont run a shitload of boost on the 18g or anything......
Old Jan 26, 2004 | 02:35 PM
This One's Avatar
Default Re: greddy turbo kit ? (hadboosttroy)
yea internal gate has nothing to do with how much boost you can run. nor does the cast manifold
The wastegae becomes somewhat eniefficient in different situations, but for your application on that turbo its more than perfect
Old Jan 26, 2004 | 02:38 PM
This One's Avatar
Default Re: greddy turbo kit ? (Spoolin18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolin18 &raquo;</TD></TR><TR><TD CLASS="quote"> Another thing...with that turbo being so small he should walk you in the quarter with it being fully spooled around 2800 RPMS. </TD></TR></TABLE>
What does that have to do with anything... how many times have you raced down the track under 2800 or even maybe 4-5k?
Old Jan 26, 2004 | 05:14 PM
Kranked
You're incorrect. The blue box has been PROVEN to support up to 15 psi on the greddy turbo AND make just as much power as a stand-alone fuel management system (i.e. Hondata, AEM, etc.) AND maintain a 12.5:1 A/F ratio under boost (the best possible turbo A/F ratio). Here's some threads as proof:
http://www.turbod16.com/viewto...cba10
H-T member Racerage1 just made 184.5WHP and 171 lb/ft. TQ on the BLUE BOX at 8 psi. Typical Hondata/AEM graphs are right around 180-195whp at 8 psi on the Greddy SOHC turbo - Sure, that's a little more power but let me put it this way:
Would you rather make:
184.5WHP @ 8 psi for $50? (average cost of greddy blue box, unless it's included with your turbo kit) on stock injectors, timing and fuel pump, and maintain a 12.5:1 AF ratio under boost? Oh yeah, it's plenty reliable as well, unless you're WOT all the time...
OR
make 195WHP @ 8 psi for around $1300? (average cost of tuned Hondata for OBD-II setup, or AEM EMS, PLUS the cost of 440cc injectors ($250-$300) and fuel pump ($100)
Sorry, but I just can't spend the cost of a greddy turbo kit ($1500) AGAIN for a few more WHP from Hondata or AEM. Keep it simple, blue box
Also, here's some other links to a greddy turbo setup on the blue box:
https://honda-tech.com/zerothread?id=208016
Quoted from that thread:
"I'm running the TD04-15G Greddy kit and intercooler, blue box, 255 in-tank pump,
B&M Commandflo, and RC 310 injectors.
The motor is stock internals, with ARP headstuds, Cometic HP headgasket, and ZEX 59300 cam. Ignition is stock.
All runs were on 92 octane, NGK BKR6E plugs gapped at .030, ignition timing at 1 degree retarded, open downpipe.
On 5 psi, it made 164.1 whp and 143.3 tq. A/F ratio was 12.5:1.
On 7 psi, it made 189.2 whp and 169.3 tq. A/F ratio was 12.5:1.
On 9 psi, it made 203.5 whp and 184.0 tq. A/F ratio was 12.0:1.
On 10 psi, it made 212.2 whp and 190.8 tq. A/F ratio was 12.0:1.
Not bad, huh? I was really surprised that I was able to run only 1 degree retarded ignition timing all the way up to 10 psi on pump gas, especially since the air temp in the dyno area was 90 degrees. Usually it's like 60 degrees around here.
And the runs above 7 psi I tuned it a little richer because I was wanted to be a little on the safer side. Maybe if I leaned it out to 12.5:1 at the higher boost levels I could make 215 whp or so."
- quoted from H-T member JFK78
To wrap it up, for you non-believers: I'm not just bench racing and saying this setup would be nice. I run the blue box on my civic (greddy kit, D16Y8, 7 psi currently). I'll be dynoing at 8 psi on stock pump and 10 psi on a Walbro this spring and I'll probably be matching JFK78's numbers as well @ 10 psi on open downpipe. As far as how the blue box runs, I'll be honest:
-idles like stock
-drives like stock, EXCEPT at partial throttle under boost (slightly boggy, but can't complain for $50)
-at WOT, runs perfectly
-maintains a consistent 12:1 - 12.5:1 AF ratio under boost to redline (dyno proven to many times)
-best reliable fuel management system for those on a budget (like under $100 budget).
I'm done.
EDIT: No I'm not! Here's another dyno of a greddy turbo SOHC at 12 psi on the blue box...213WHP / 218 lb./ft. TQ!!!!!!!!!
http://www.turbod16.com/viewto...00036
Modified by boostincoupe at 8:24 PM 1/26/2004
Old Jan 26, 2004 | 05:21 PM
90crxzc's Avatar
greddy kit is a great kit for a street setup, quick spooling, u dont have to wait till 5000rpm for the boost to kick in, get a boost controller and the greddy kit is good to about 15psi
Old Jan 26, 2004 | 06:01 PM
Del_Slowest's Avatar
Default Re: (90crxzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxzc &raquo;</TD></TR><TR><TD CLASS="quote">greddy kit is a great kit for a street setup, quick spooling, u dont have to wait till 5000rpm for the boost to kick in, get a boost controller and the greddy kit is good to about 15psi</TD></TR></TABLE>
which one are you talking about. the SOHC one is only good till 11-12psi. look at the compressor charts
Old Jan 26, 2004 | 06:18 PM
Racerage1's Avatar
yes, it would work. i have the exact same model car as you and running the 92-95 kit. you'll love the power right out the box
check sig
