ITR shift linkage
Old Jan 25, 2004 | 04:13 PM
ScorpioX's Avatar
Default ITR shift linkage
i currently have a GSR shift likage on my ITR/Civic hybrid,
is there a difference between a GSR and a ITR shift linkage?
and what shiftlinkage bushings will make the shifting smoother?
thx all
Old Jan 25, 2004 | 06:30 PM
92TypeR's Avatar
FSAE
Default Re: ITR shift linkage (ScorpioX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioX &raquo;</TD></TR><TR><TD CLASS="quote">i currently have a GSR shift likage on my ITR/Civic hybrid,
thx all
Same.
I believe in Japan there was a year when the ITR shift linkage was bronze, supposedly has a 10% shorter throw, but I have no evidence to back this up.
The ES shifter bushings are very good from what I hear.
Old Jan 25, 2004 | 08:14 PM
R6Boy69's Avatar
yeah get some of those polyurethane bushings... they make the shifter feel "firmer", there are a couple companies that make them...
Old Jan 25, 2004 | 08:30 PM
MAD ITR 55's Avatar
I use energy suspension shifter bushings.I like them plus they are cheap.
Old Jan 25, 2004 | 10:58 PM
seek167's Avatar
Default Re: (MAD ITR 55)
type r linkage is bigger then gsr
Old Jan 26, 2004 | 04:36 AM
Jason's Avatar
Default Re: (seek167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seek167 &raquo;</TD></TR><TR><TD CLASS="quote">type r linkage is bigger then gsr </TD></TR></TABLE>
no, it's not...it's the same
I had the ES kit, cheap and much nicer than the OEM rubber
Old Jan 26, 2004 | 05:29 AM
00MRSi's Avatar
Default Re: (Jason)
Bushings should make it feel better. I have Mugen bushings installed with ITR shift linkage and my Cs shifter. Bushings work well...
Old Jan 26, 2004 | 05:31 AM
Willard's Avatar
Default Re: (Jason)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason &raquo;</TD></TR><TR><TD CLASS="quote">no, it's not...it's the same</TD></TR></TABLE>
I thought the rear section of the shifter had a extra weight? :shrugg:
they are the same shape/lenght tho.
Old Jan 26, 2004 | 05:43 AM
Bbasso's Avatar
I use energy suspension shifter bushings, but I don't think it made it any smoother, infact I think I miss more then before.
Old Jan 26, 2004 | 09:54 AM
mstewar's Avatar
they are the same size, shape, etc and are interchangeable.
the stabalizer bar is exactly the same. the shifter bar that actually connects to the transmission is slightly different, and I think it's due to weight. Slightly different part numbers on this piece.
And the aforementioned color differences.
Honestly, I don't think it makes much difference. BTW, I use an OEM shifter, OEM shift linkage, and ES bushings. I love the setup.. very smooth and firm..
Old Jan 26, 2004 | 11:21 AM
seek167's Avatar
Default Re: ITR shift linkage (mstewar)
mstewar so type r is different from gsr
Old Jan 26, 2004 | 11:41 AM
mstewar's Avatar
Default Re: ITR shift linkage (seek167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seek167 &raquo;</TD></TR><TR><TD CLASS="quote">mstewar so type r is different from gsr</TD></TR></TABLE>
technically, yes.. are they interchangeable? yes.. will you be able to feel a difference between the two? probably not..
Old Jan 26, 2004 | 11:44 AM
seek167's Avatar
thanks i was pretty sure they were diff
Old Jan 26, 2004 | 12:00 PM
Tweakmeister's Avatar
Default Re: (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
they are the same shape/lenght tho. </TD></TR></TABLE>
Funny you mention that, many people (not necessarily teg owners) will chop off those weights. ?!?
Old Jan 26, 2004 | 01:26 PM
ArinX's Avatar
Default Re: ITR shift linkage (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
I have the bronze one in my hybrid and i dunno about 10 percent but it sure does feel shorter
Old Jan 26, 2004 | 08:53 PM
ITR#132's Avatar
Actually you are correct. Type R linkage is beefier than GsR/LS/RS linkage (At least up to 98 GsR; I am not sure if they changed the GsR after that to the same as ITR)
Old Jan 26, 2004 | 09:28 PM
mstewar's Avatar
Default Re: (ITR#132)
i've had the two side by side.. it's not as much of a difference as you think..
SoyMilk
Jul 2, 2007 02:12 PM
G2DAB18
Feb 5, 2006 08:38 AM
G2DAB18
Feb 3, 2006 03:49 AM
.:JEROME:.
Sep 12, 2005 07:16 PM
MugenGTR
Jul 22, 2003 11:49 AM
