Easy cable VSS question, pic inside
Old Jan 25, 2004 | 02:33 PM
ITR981002's Avatar
Default Easy cable VSS question, pic inside
Alright, this one had me stumped until I found something on the web today about the power steering in the teg. I don't have power steering so I'm guessing I can just pour a little MTL down one of the holes and then loop 1 and 2 together right?
Old Jan 25, 2004 | 02:38 PM
TwztdSi's Avatar
I saw somthing on the web about that also. Except the person used brake fluid to fill it and than looped it together.
Old Jan 25, 2004 | 02:40 PM
1's Avatar
Default Re: (TwztdSi)
Just plug the ends up.
Old Jan 25, 2004 | 02:55 PM
cursED's Avatar
Default Re: Easy cable VSS question, pic inside (ITR981002)
I looped mine, no fluid added. No problems after almost 10K miles.
Old Jan 25, 2004 | 03:02 PM
fourthgenhatchB17's Avatar
Default Re: Easy cable VSS question, pic inside (milk)
What u can do is just swap out that teggy unit and replace it with a D series one. Why would u need to add fluid??
Old Jan 25, 2004 | 03:06 PM
1's Avatar
Default Re: Easy cable VSS question, pic inside (fourthgenhatchB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">What u can do is just swap out that teggy unit and replace it with a D series one. </TD></TR></TABLE>
Exactly, then your speedo would be correct.
Old Jan 25, 2004 | 07:19 PM
ITR981002's Avatar
I was just thinking the fluid would lubricate the gear... but I guess the non-power steering ones don't have any at all anyway... so i'll just loop it and call it a day. Thanks guys.
Old Jan 25, 2004 | 07:21 PM
FAUCON's Avatar
Here too, just loop, no liquid added. Work perfect since 2years. And will stay like that
Old Jan 25, 2004 | 07:25 PM
JonGP4's Avatar
Default Re: (FAUCON)
all it does it correct the power steering at high speeds so people who can't drive don't loose control.. loop it if u must, but it won't damage anything is u don't
Old Jan 25, 2004 | 07:30 PM
ThatRicerDaniel's Avatar
Default Re: (JonGP4)
i swapped mines with a d-series.
Old Jan 25, 2004 | 08:42 PM
Origin's Avatar
Default Re: (NitrousDreamz)
probably another stupid post. but why does this effect your speedo? i know it assist when you drive faster, but im not getting the speedo part.
Old Jan 25, 2004 | 08:45 PM
1's Avatar
Default Re: (Origin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Origin &raquo;</TD></TR><TR><TD CLASS="quote">probably another stupid post.</TD></TR></TABLE>
Have you checked the gearing on both the D-series and B-series VSS?
marc-111
Mar 23, 2006 10:40 PM
rac3rb0i
Mar 16, 2006 10:56 AM
bethsg
14
Aug 22, 2005 08:36 PM
Stolen R
Feb 2, 2005 09:10 AM
pineapplemike
Oct 13, 2003 09:32 AM
