Wiring Gurus heres a question---------SiR engine harness to DX harness
Old Jan 25, 2004 | 02:11 PM
virginia_dude's Avatar
Default Wiring Gurus heres a question---------SiR engine harness to DX harness
How many wires on this are on correct pins from the DX to the SiR. I know there will be extra wires to run for the Vtec knock sensor ETC. When I converted my DX engine harness for MPFI on my ZC I pulled today I bypassed those connectors so they are unmollested. My SiR engine Harness is complete and unmolested. The plugs are compatible, but clearly the drivers side one has a few extra wires, the passenger side on both are full. Anyone see diagrams comparing these connectors. as far as signals go. Obviosly this is a B16A1 engine.
Old Jan 25, 2004 | 02:46 PM
Davep's Avatar
Default Re: Wiring Gurus heres a question---------SiR engine harness to DX harness (virginia_dude)
The wiring is very different it's much easier to use your old MPFI harness that you have and add the B16A wires that you will need.
Old Jan 25, 2004 | 03:25 PM
Default Re: Wiring Gurus heres a question---------SiR engine harness to DX harness (Davep)
Well I damaged the old harness pulling the old motor. Repinning the connector would be very easy for me. Easier than repairing the harness I had. if I knew color codes and signals on the connectors I could do that easily, like in 30 minutes.
connector is the same its easy to pop and move pins.
Old Jan 25, 2004 | 08:13 PM
Got to be someone who can answer this. Re pinning two connectors is far easier then unscrewwing a damaged harness.
gsr336
Feb 28, 2007 07:33 AM
johnzm
May 31, 2004 11:49 AM
highmilehatch
Aug 8, 2003 04:05 AM
