Type R intake manifold on a b16?
Old Jan 25, 2004 | 12:30 PM
Quickr's Avatar
Default Type R intake manifold on a b16?
Can you put a b18c5 intake manifold on a b16a1 engine? if possible, how much hp can you expect to gain?
Thanks
Old Jan 25, 2004 | 12:36 PM
GoFastMotorSports's Avatar
Default Re: Type R intake manifold on a b16? (Quickr)
Don't know about hp gain,but b series is b series and it will fit. Shouldn't be a huge gain but I would imagine it will flow better
Old Jan 25, 2004 | 12:41 PM
Quickr's Avatar
Alright, is it generally easy to swap the manifolds?
Old Jan 25, 2004 | 12:52 PM
Trevor's Avatar
I am pretty sure that one from a b18c will not fit the b16a but I think the b18c5 from the type r will work.
I could be wrong but I think the ports on the head are not the same.
Old Jan 25, 2004 | 01:17 PM
Redline130's Avatar
Default Re: Type R intake manifold on a b16? (Trevor)
The ITR manifold will fit on the B16A head. The ITR manifold will not fit on the LS or GSR heads (with the exception of the B17A). In order to use the ITR manifold on the B16A, you will also need to use a ITR or GSR fuel rail. This is because of the placement of the air intake temp sensor on the #2 runner instead of the #1 runner. As for HP gains, unless you also use Type-R cams and a larger throttle body, you probably won't see more than 2-3 hp if that. You will probably also lose some power in the lower RPM range.
Old Jan 25, 2004 | 03:24 PM
Blown90hatcH's Avatar
Default Re: Type R intake manifold on a b16? (GRCCRX911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRCCRX911 &raquo;</TD></TR><TR><TD CLASS="quote">Don't know about hp gain,but b series is b series and it will fit. Shouldn't be a huge gain but I would imagine it will flow better</TD></TR></TABLE>
Incorrect...ITR will fit B16a and late B17a. It will not fit LS, Gsr, CRV.
88 EF Hatch
11
Nov 27, 2008 06:48 PM
AP1_man
Feb 24, 2007 11:58 PM
whitemike1644
Aug 25, 2003 08:12 AM
BluFire
Dec 28, 2002 09:33 PM
Brian_92GSR
Mar 17, 2002 09:58 AM
