crx overheating not getting heat
Old Jan 25, 2004 | 10:35 AM
CRXracer88's Avatar
Default crx overheating not getting heat
ok here in ohio its cold as fock and i didnt drive my car for 2 days and then i went out to start it up it wouldnt barely start but after i let it run for 15 mins. i went out and the heater wasnt blowing any heat. so i took off down the road and the temp gauge started to go up it went almost all the way up but if i just let it sit there and idle the temp gauge comes back down were it normaly is. so wut do you guys think it is thermostat or head gasket . coolant level is fine. its the first time ive had this problem. any help thanxs
Old Jan 25, 2004 | 10:36 AM
riceboyEFsi's Avatar
Default Re: crx overheating not getting heat (CRXracer88)
thermostat
Old Jan 25, 2004 | 10:46 AM
sircrxracer's Avatar
I had this same problem in my ZC I bet your Head gasket is going, my sure you check your coolant often. Rob
Old Jan 25, 2004 | 11:18 AM
CRXracer88's Avatar
Default Re: crx overheating not getting heat (sircrxracer)
i think the fel-pro head gasket might be the problem i put one in last winter i was poor and being cheap thats why i used fel-pro junk . But im going to do a block test on it and se wut happens.
DTHADDR
11
Feb 5, 2013 12:28 AM
EnviedByMany
Mar 25, 2010 04:46 PM
jdmcivic1
10
Jun 12, 2009 02:29 PM
PINKS
Oct 24, 2006 10:59 PM
Cashflo
Aug 15, 2002 12:37 AM
