snaped cam bolt off in head
Old Jan 25, 2004 | 04:20 AM
combustin's Avatar
Default snaped cam bolt off in head
Well I just got a 1992 prelude 2.3 for $1000, the timing belt broke and bent 6 valves. I rebuild the head and put everything back onto the car, when I went to torque down the cams on my intake side the long bolt snapped off inside the head. I’m not sure what I should do? do you think a machine shop can get it out or do you think i should scrap the head. It is so deep you can barley get a drill down in there.
thanks,
mike
Old Jan 25, 2004 | 05:34 AM
nickzed20's Avatar
Default Re: snaped cam bolt off in head (combustin)
best way to find out would be to bring it to a local machine shop and ask if they can drill it out for you.
Old Jan 25, 2004 | 11:10 AM
Kendall's Avatar
Default Re: snaped cam bolt off in head (nickzed20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickzed20 &raquo;</TD></TR><TR><TD CLASS="quote">best way to find out would be to bring it to a local machine shop and ask if they can drill it out for you.</TD></TR></TABLE>
Even if it can't be drilled out, then you can have the hole redrilled (which would destroy the broken bolt) and have it retapped.
By the way, welcome to Honda-Tech.
Old Jan 25, 2004 | 01:32 PM
doublejz's Avatar
Default Re: snaped cam bolt off in head (Kendall)
i did the same thing, if its that deep and theres enough threads to put a shorter bold in then do that. I have been running my car with a broken on since Nov haven't gotten around to it yet
Old Jan 25, 2004 | 02:03 PM
nickzed20's Avatar
Default Re: snaped cam bolt off in head (doublejz)
i dont know if i would do that... it would still need to go in pretty deep... i would rather just pay the machine shop how ever much it costs and do it right for good, then to run into major problems later on.
Old Jan 25, 2004 | 03:25 PM
combustin's Avatar
I just got the head off and im going to take it to a machine shop tomorrow. If it is really bad he can probably tap a size bigger and put in a helicol so I can still run the stock bolt size. Does anyone know the exact torque spec for those cam bolt caps.
Thanks,
mike
bow tie
Nov 15, 2008 05:11 PM
Burton7706
Jan 23, 2007 05:32 PM
Beau Gotti
Sep 10, 2006 12:25 PM
Hondaholik
Jul 24, 2006 04:47 PM
