Blinker does not blink, just stays lit constantly when turned on.
Old Jan 24, 2004 | 06:52 PM
Fuster_Cluck's Avatar
Default Blinker does not blink, just stays lit constantly when turned on.
When I turn the left blinker on the bulbs light up, but do NOT blink. The right turn signal works fine. Any idea of the cause? Possibly a bad relay?
It's an old school 75 Honda CB200T
Thanks!
Old Jan 24, 2004 | 07:02 PM
Etylorcen's Avatar
Default Re: Blinker does not blink, just stays lit constantly when turned on. (Hybrid93Hatch)
Check the wiring on bulb on the other signal. If yer front isnt working check the rear too or vice versa.
Old Jan 25, 2004 | 05:54 AM
92hybridhhatch's Avatar
From: from Brooklyn NY U.S. Army recruiter in Holyoke, MA, USA
Default Re: Blinker does not blink, just stays lit constantly when turned on. (Etylorcen)
does the front blinker work?
Old Jan 25, 2004 | 07:34 PM
Default Re: Blinker does not blink, just stays lit constantly when turned on. (92hybridhhatch)
Rode the bike tonight. Now both blinkers are having this problem. All 4 bulbs work. Just when I signal to turn they don't blink, just stay lit constantly.
Old Jan 30, 2004 | 01:54 PM
90Ninja
Guest
Posts: n/a
Not sure if those have flashers or not. If it does that's your problem.
Old Jan 30, 2004 | 06:08 PM
eg94b18's Avatar
my old r6 had this problem and as weird as it sounds the reason was my battery was slowly dying.got a new battery and everything was fine.and yes it was starting up just fine when the battery was dying.also it might be one of the wires to the blinker is loose.it would be the wire that causes it to blink not flash.there should only be two wires going to the blinker front and rear.hope this helps and good luck getting it fixed.
AdamAccord
Nov 7, 2017 05:19 PM
Edul59
Sep 10, 2010 03:33 PM
HondaAccordTdR
Honda Motorcycles
Sep 28, 2007 11:57 AM
Uncle Ben's
Jul 8, 2007 12:08 PM
CIVIX
Nov 1, 2002 12:02 PM
