Another light problem
Old Sep 27, 2007 | 08:46 AM
HondaAccordTdR's Avatar
Default Another light problem
Well, much to my demise i cant figure out what the hell the problem is. I have a 1991 GSXR 1100, and there is a problem with nearly all of the lights on the front of the bike. Neither headlights work, the running lights/blinkers are very dim and turn off when i activate the turn signal. The rear running/blinkers work except when i turn on the signal, they light up and stay that way... no blink. The tail/brake light works fine. I checked all of the bulbs and the fuses. The battery is fine, the bike starts up right away. They dont even turn on when the bike is running. Argh!
Old Sep 27, 2007 | 11:12 AM
4-ageTOg63's Avatar
Default Re: Another light problem (HondaAccordTdR)
The main problem is that you need to sell me the bike...
Ok seriously though...you need to pull your fairings off and check your pinn connectors on all the plugs...front and back.
Check the wires thuroughly.
Then get a haynes and check all the relays.
Old Sep 27, 2007 | 11:13 AM
MSchu's Avatar
My Name is Nobody
Default Re: Another light problem (4-ageTOg63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-ageTOg63 &raquo;</TD></TR><TR><TD CLASS="quote">The main problem is that you need to sell me the bike...</TD></TR></TABLE>
Hahahahaha.... nice!
Make sure the harness is properly ground
Old Sep 27, 2007 | 11:15 AM
4-ageTOg63's Avatar
Default Re: Another light problem (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">
Make sure the harness is properly ground</TD></TR></TABLE>
I just clicked back in here to edit my post and add that.
For real though...the early 90's 1100s are my dream bike.
Big bore kit, car tire conversion, shaved seat, raked forks, gobs of nitrous, air shifter....bam, mid 8 second bike. Those motors lovvvvvve nitrous.
Old Sep 28, 2007 | 10:28 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Make sure the harness is properly ground</TD></TR></TABLE> +1
Old Sep 28, 2007 | 11:57 AM
Default Re: Another light problem (ScareyH22A)
Ill check it out. If it was a ground problem, would the bike still be able to start? The bike starts just fine and the rear lights work. ?
linden940
Honda Motorcycles
Sep 27, 2008 06:11 PM
p4eAaLcLe
Honda Motorcycles
Aug 19, 2008 10:23 AM
5po0n_Dc2
Honda Motorcycles
Oct 14, 2005 11:12 AM
umar456
Honda Motorcycles
Jul 20, 2003 08:35 PM
