Type S shifting??????????
Old Jan 24, 2004 | 04:59 PM
mattjcali22's Avatar
Default Type S shifting??????????
I have noticed when I am shifting through my gears it is a little stiff putting it into the next gear. Is this normal on the RSX or is my sync messed up. I just got the car and I really hope nothings wrong.
Old Jan 24, 2004 | 05:37 PM
OoHiTzToMMy's Avatar
it should be really smooth shifting.... do u step down on the cluch all the way?
Old Jan 24, 2004 | 05:43 PM
dashark's Avatar
Default Re: (OoHiTzToMMy)
I'm actually getting my synchros replaced by Acura. I have a Type S with 15 000 Kms and they are changing the synchros for 1st, 2nd and 3rd gear.
It's a chronic problem on RSX's.... See http://www.clubrsx.com, they have over 100 topics about the grinding of gears.
Old Jan 24, 2004 | 08:42 PM
Steve26's Avatar
he didn't mention any grinding, just stiff...
Old Jan 24, 2004 | 09:03 PM
Default Re: Type S shifting?????????? (mattjcali22)
it is starting to grind a little into second. I am pushing the clutch to the floor. i think it is progessively getting worse.
Old Jan 24, 2004 | 11:49 PM
smoknuinmyrsx's Avatar
u have just caught the 1-2 grinding virus.
Old Jan 25, 2004 | 08:25 AM
TrueZen's Avatar
I know there's apparent problems with the 1-2 shift in the RSX, even though I've rarely encountered this. One definate solution may be to change the tranny fluid. That may help with shifting stiffness. How many miles are on the car now?
Old Jan 25, 2004 | 10:53 AM
Default Re: Type S shifting?????????? (TrueZen)
26500
Old Jan 25, 2004 | 11:03 AM
TrueZen's Avatar
It won't hurt to change it now, most often it is changed at the 30K service. A quart of MTF should run $7-8 and I doubt that you would need any more than 3 to change it. If you have any questions, just ask.
Old Jan 25, 2004 | 11:04 AM
k0reanrenegade's Avatar
hey.. does the ep3 sometimes come with a shifting problem ? mine grinds from 1-2 sometimes and im 100% sure i pressed clutch all the way down.. i dont get it.
Old Jan 25, 2004 | 11:05 AM
TrueZen's Avatar
And I might also suggest picking up the magnetic drain plugs from Spoon, it'll help clear up any shavings/metal debris that may be floating in there and possibly interfering with your shifting. I'm actually going to pick some up soon. Check out http://www.aj-racing.com if you think they'll help.
Old Jan 25, 2004 | 11:08 AM
TrueZen's Avatar
Default Re: Type S shifting?????????? (sivaji)
I believe the 1-2 shift throw is slightly longer than it seems at times. I'm going to be more careful in shifting(especially after my recent mistake ) and take a little longer between shifts to make sure it's all the way in. You could just be throwing it in and letting off the clutch just slight too quick. That's just my guess though since I haven't seen you drive.
Old Jan 25, 2004 | 11:11 AM
TrueZen's Avatar
Sorry sivaji, to actually answer your question, I haven't heard of this problem from ep3's, but I wouldn't be completely surprised if the same happened with them.
it grinds on the way into 2nd, while my foot is still down on the clutch all the way.
i fully clutch, throw my gear into second, and it grinds.
Old Jan 25, 2004 | 12:06 PM
iam going to change fluid and see if that helps.
Old Jan 25, 2004 | 01:00 PM
TrueZen's Avatar
Well, then most likely it's the same problem, matt only said that the shifting was stiff.
Old Jan 25, 2004 | 10:54 PM
sinical-ep3's Avatar
1-2 grind in the ep3 used to happen to me before. It rarely happens nowadays (when its really cold or something). The only thing I could say about it is that I now make sure that I pull straight down...not down and left (holding the shifter from the side caused me to do this). Now I just hold it from the top, and shift up and down with mere wrist movements, and it feels perfect.
Old Jan 26, 2004 | 03:44 AM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattjcali22 &raquo;</TD></TR><TR><TD CLASS="quote">I have noticed when I am shifting through my gears it is a little stiff putting it into the next gear. Is this normal on the RSX or is my sync messed up. I just got the car and I really hope nothings wrong. </TD></TR></TABLE>
What I do know is let the transmission fluid get to operating temperature, Thats what Honda says it has to be at before an accurate estimate can be made.
(like engine warmed up and such)
Sometimes mine is stiff going into second, but after it gets warmed up its good.
Old Jan 26, 2004 | 07:53 AM
ITR_1211's Avatar
Default Re: Type S shifting?????????? (GreenBean)
I changed my tranny fluid to MTL at 8K and it made a big difference
Others have used GM syncro friction modifier and claims grinding is completely eliminated. I might try that on my next trans fluid change but so far I'm happy with MTL
Old Jan 26, 2004 | 08:08 AM
Hooligan317's Avatar
Default Re: (smoknuinmyrsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smoknuinmyrsx &raquo;</TD></TR><TR><TD CLASS="quote">u have just caught the 1-2 grinding virus. </TD></TR></TABLE>
that's not good definately check out clubrsx for more info
Old Jan 26, 2004 | 10:26 AM
H22A EG6's Avatar
Default Re: (Hooligan317)
i ******* hate trannys
Old Jan 26, 2004 | 12:11 PM
Default Re: Type S shifting?????????? (Darryl Musashi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darryl Musashi &raquo;</TD></TR><TR><TD CLASS="quote">I changed my tranny fluid to MTL at 8K and it made a big difference
Others have used GM syncro friction modifier and claims grinding is completely eliminated. I might try that on my next trans fluid change but so far I'm happy with MTL </TD></TR></TABLE>
I am going to give the GM syncro friction modifer. Can I get that at any auto parts store? The sifting seems to improve when it gets warm.
Old Jan 26, 2004 | 05:07 PM
Jim Truett's Avatar
Personally I cannot endorse the GM Synchromesh. I was running Royal Purple Synchromax in my 6 speed, and I had a slight "notchy" feeling when shifting to second. With the GM Synchromesh (friction modified) the grind was actually worse when cold, and it made the downshift from 3rd to 2nd very stiff. The GM Synchromesh is very thin, and this may be why.
Old Jan 26, 2004 | 06:45 PM
Default Re: Type S shifting?????????? (Jim Truett)
What about Redline transmission fluid. here is a discrption from summit:
"Red Line gear oils and transmission lubricants are designed to provide excellent low temperature shift ability and improved gear protection at higher temperatures. They will reduce differential and transmission temperatures 10-70 degrees F, while efficiency improvements between 1 and 5 percent are typical. The synthetic base stocks used have tremendous thermal stability and provide the best film strength available. Their unique combination of base stocks and additives allow them to carry higher loads compared to petroleum lubricants, and their stability allows them to be used for extended periods."
What do you guys think, will this work? Oh, what weight of oil would I use? they have different weights.
Old Jan 26, 2004 | 07:12 PM
ITR_1211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
Personally I cannot endorse the GM Synchromesh. I was running Royal Purple Synchromax in my 6 speed, and I had a slight "notchy" feeling when shifting to second. With the GM Synchromesh (friction modified) the grind was actually worse when cold, and it made the downshift from 3rd to 2nd very stiff. The GM Synchromesh is very thin, and this may be why.</TD></TR></TABLE>
Jim, most of the R guys were using the friction modified fluid and claimed it had gotten rid grinds. How long did you have it in before it got worse? or was like it that to begin with?
