11:1 GSR block, B16 head, which oil pan?
Old Jan 24, 2004 | 04:48 PM
kingrobby's Avatar
Default 11:1 GSR block, B16 head, which oil pan?
The GSR block is a 3.210 bore with 11:1 pistons, stock B16 Vtec head. We are using the stock B16 oil pump,is this alright? Also, i know the B16 oil pan wont fit so do we use the GSR oil pan, pickup and baffle? I dont have a GSR pan otherwise i could see myself. Its going into a LS, would that pan work?
What do you guys think of port matching the intake manifold and the exhaust. Not talking about major porting just opening them up alittle bit to match the manifolds. Thanks in advance. You can always count on good info here on Honda-tech.
Modified by kingrobby at 6:08 PM 1/25/2004
Old Jan 25, 2004 | 09:09 AM
kingrobby's Avatar
Default Re: 11:1 GSR block, B16 head, which oil pan? (kingrobby)
Anybody?
Old Jan 25, 2004 | 10:02 AM
Kendall's Avatar
Use the GSR oil pan, the LS one will not fit.
Old Jan 25, 2004 | 10:06 AM
Kendall's Avatar
Port matching should be good for a few horses, but establish your goals first. I'd much rather spend a few bucks and get the AEBS intake manifold than to spend the money port matching the stock manifold, just due to the fact that it flows a hell of a lot better. Also if you're using the stock exhaust manifold, get a good header, like the JDM DC 4-1, not the regular ones that everyone sells.
Old Jan 25, 2004 | 11:51 AM
kingrobby's Avatar
Thanks for the info and opinion on the AEBS manifold, we do have an aftermarket header too. I now know to use the GSR pan, pickup and baffle, but will the B16 oil pump flow enough to run the vtec on the GSR block.
Old Dec 20, 2004 | 05:07 PM
AllMotr's Avatar
yes the b16 pump will work, it aswell is meant for 8000rpm.
sabele
Feb 6, 2009 06:27 PM
eRACING
Nov 23, 2004 03:46 AM
dkim48
Nov 10, 2004 06:08 PM
mchuang
Mar 31, 2004 05:58 PM
