I need valvetrain help
Old Jan 24, 2004 | 04:04 PM
carl_aka_carlos's Avatar
Default I need valvetrain help
So two weeks ago my car developed a lovely tick coming from the valvetrain. Bought a FSM, and went ahead and did a valve adjustment this afternoon.
Intake side was at .008in all across the board, brought them back to .004. Exhaust was .009 all across, brought them back to .006in. The tick is still there, so I'm assuming that it isn't a valve related tick. Now I have no idea what it could be.
This is on a 1994 Integra RS with 150,000 miles. I get good oil pressure, timing belt and water pump are only 45k miles old. What else could it possibly be? The car still pulls hard, still runs perfect, aside from that annoying tick that rises and falls with the engine speed.
I'm really frustrated here
Old Jan 24, 2004 | 04:12 PM
.RJ's Avatar
.RJ
Default Re: I need valvetrain help (carl_aka_carlos)
Did you do the valve adjustment while the engine was *hot* ?
.004/.006 seems a little loose for a high mileage motor, i'd try .003/.005
If it still doesnt go away... i dont know
hondatim's Avatar
did you adjust them cold or hot? Can make a difference...
Old Jan 24, 2004 | 04:16 PM
Default Re: I need valvetrain help (hondatim)
i did it exactly as the FSM said, with the head under 100*F
Old Jan 24, 2004 | 04:20 PM
well, i guess i'll tighten the intake to .003 and the exhaust to .005 in the morning, see if that helps.
thanks for the help guys
Old Jan 24, 2004 | 06:53 PM
Aahj's Avatar
Are you adjusting the correct valves at proper TDC configurations?
Also, buy a cheap mechanics stethoscope to pinpoint the tic. They work extremely well.
good luck,
AJ Nealey
1996accordlx2_2
Feb 26, 2018 11:43 PM
Marcg611
Aug 24, 2008 08:04 AM
SpeedoKing
Nov 6, 2007 09:18 AM
VTECth1s
Jul 30, 2006 06:15 AM
mickey513
Feb 19, 2002 10:50 PM
