High idle w/loping
Old Jan 24, 2004 | 03:34 PM
notstock93's Avatar
Default High idle w/loping
Just swapped a B16 block with B18c head in my DA integra, and now that im done, the idle is very high. It stays at about 1500 with a distinct "lope" sound. I have a few cels, one for knock, one for VTEC solenoid, and im using a stock OBD-I P72 ECU. I cant see/hear any vacuum leaks and the throttle cable is tight, but is shutting the throttle plate all the way (made sure).
Cams are stock GSR cams. When you open the hood, you can see the engine shake from the lope. Any ideas?
I searched, but I mostly found things about TPS and IACV. None of the posts dealt with an engine that lopes at 1500 RPM.
Old Jan 24, 2004 | 04:01 PM
hondatim's Avatar
Default Re: High idle w/loping (notstock93)
Sure you don't have a lean miss due to vacuum leak or something?
Any more info you could give would be great..
Old Jan 24, 2004 | 04:07 PM
notstock93's Avatar
Default Re: High idle w/loping (hondatim)
Can I bring my car to you tomorrow? I'll call you tomorrow to talk to you.
TheAverageBear
Aug 16, 2009 09:34 PM
porter351
Jul 22, 2009 02:30 AM
90Rexx
Jul 2, 2008 08:53 AM
RedEj8
Feb 19, 2006 01:36 PM
Used2beAb16
Mar 30, 2004 02:57 PM
