Lug studs stripped, help taking out
Old Jan 24, 2004 | 03:15 PM
weraider30's Avatar
Default Lug studs stripped, help taking out
i have the rotor, and caliper off, but i can't get the hub off, anybody know how to take it off?
Old Jan 24, 2004 | 03:29 PM
LudeyKrus's Avatar
rubber mallet, large flathead screwdriver, and a pry bar. That's all you really need, aside from hand tools.
Old Jan 24, 2004 | 03:43 PM
weraider30's Avatar
Default Re: (LudeyKrus)
explain how
Old Jan 24, 2004 | 06:59 PM
benSC's Avatar
The hub is pressed in, you might damage it by wailing on it with a hammer. Just trim the dustguard, and pound them out.
Old Jan 24, 2004 | 07:08 PM
Sliced Beard's Avatar
Default Re: (benSC)
what kind of car do you have
if it is a civic with only 9.3" brakes you can beat them out with a big hammer and replace them by hitting them back in
BUT if you have an integra or a car with 10.3" brakes the knuckle is designed differently and you will have to get the hub pressed out and have the studs replaced. by pressing the hub out it messes up the bearing most of the time so i would reccomend getting a new bearing also
this should cost you around 90 bux to get done at a reputable shop including the bearing and studs
peppers75
Honda CR-V & Element
15
Jun 25, 2011 09:31 AM
SomeGoodBud2
Suspension & Brakes
Mar 18, 2007 02:48 PM
AlizeVS
Oct 6, 2004 05:37 PM
PA MATT
Aug 22, 2003 12:08 PM
jlamaster
Jul 25, 2003 01:18 PM
