Hondata question (RSX-S)
Old Jan 24, 2004 | 02:24 PM
dashark's Avatar
Default Hondata question (RSX-S)
I want to purchase the K20A2-4: 5200 VTEC point and 8600 rpm REV limit for my Type S, but I do not want to have problems with my warranty with Acura.
This is my question.... Can I purchase a used ECU off another Type S, Flash that one and keep my own ECU if ever I have problems.
This way, if something screws up, I can swap the ECU to my stock one and bring it into Acura....
Thanx !
Old Jan 27, 2004 | 03:24 PM
GreenBean's Avatar
Default Re: Hondata question (dashark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dashark &raquo;</TD></TR><TR><TD CLASS="quote">I want to purchase the K20A2-4: 5200 VTEC point and 8600 rpm REV limit for my Type S, but I do not want to have problems with my warranty with Acura.
Thanx !</TD></TR></TABLE>
I am sure you could purchase another ecu, Problem is the immobilizer unit has to be programmed with the ecu you are going to use...It doesn't sound possible.
Old Jan 27, 2004 | 03:34 PM
ITR_1211's Avatar
Default Re: Hondata question (GreenBean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean &raquo;</TD></TR><TR><TD CLASS="quote">
I am sure you could purchase another ecu, Problem is the immobilizer unit has to be programmed with the ecu you are going to use...It doesn't sound possible.</TD></TR></TABLE>
What if he was to send the ECU he bought along with his current immobilizer and key to hondata and toss his exisiting ECU to the side?
If something goes wrong, he should be able to just plug his old ECU back in and it should work should it not?
Old Jan 27, 2004 | 04:48 PM
DC5ITR329's Avatar
Default Re: Hondata question (Darryl Musashi)
If you get a another ECU you can have the dealer program the immobilizer for 100 bucks. Hondata can also flash you car to stock for 75 bucks I think. by this I mean they can make the fuel map and timings stock.
Old Jan 30, 2004 | 07:32 PM
GreenBean's Avatar
Default Re: Hondata question (aznbo1626)
The ecu has to read the immobilizer and the correct key before the ecu will let the vehicle run.
Old Jan 30, 2004 | 07:42 PM
ITR_1211's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean &raquo;</TD></TR><TR><TD CLASS="quote">The ecu has to read the immobilizer and the correct key before the ecu will let the vehicle run.</TD></TR></TABLE>
So then if he sends his new ECU in to be programmed with that immobilizer, effectively both ECUs should be ok to be used with that 1 immobilizer then?
Old Jan 31, 2004 | 04:28 AM
GreenBean's Avatar
They could be, I'd call Hondata and see if that would be the case....
Old Jan 31, 2004 | 05:20 AM
dcfive's Avatar
why couldn't you just takethe immoblizer out of whatever car he's getting the other ecu from? so then he would have two ecu's and two immoblizers. One for each.
Old Jan 31, 2004 | 12:02 PM
Payntech's Avatar
You can purchase another ECU and send that one with the immobilizer and key to be flashed. Both ECU's will then be matched to the same key and immobilizer, so you can swap them. The dealer cannot detect a Hondata reflash and Hondata will swap the stock flash in if you need to have any heavy work performed.
If you have any questions, please feel free to contact us.
Thanks,
Old Jan 31, 2004 | 07:00 PM
GreenBean's Avatar
Default Re: Hondata question (Payntech)
Do you know when the engine over-speed condition code will come up?
After 8,100 the factory ecu records the freeze-data.
And throws that code....Once the engine is past fuel cut If I am correct.
Old Jan 31, 2004 | 07:35 PM
Hondata's Avatar
Default Warranty / engine over-rev code
Research the Magnuson-Moss Warranty Act, a summary of which is present on the SEMA site: http://www.enjoythedrive.com/c...=8034
The warranty question comes up quite often. The law is that Acura must cover warranty work on the vehicle unless the modification causes the problem. Since Honda engines only die if you use nitrous, boost or over-rev them, then you should be fairly safe. Much depends on the dealer - some try to scare their customers by implying that their warranty will be void if the customer modifies anything. Our local Acura dealer (South Bay Acura) sends cars to us to get re-flashed from new, so at least some dealers are comfortable with Hondata modifying ECUs.
The engine over-rev error is only generated if the engine speed exceeds 9000 rpm. Since all our ECU rev limits are below 9000 rpm, the error will only be generated if you mis-shift.
akaEsCo01
Nov 24, 2004 09:02 PM
MiguezVTI
Sep 2, 2004 10:17 AM
aznboysrfr
11
Jul 25, 2004 08:00 PM
JoeyBallzSI
Apr 25, 2004 05:13 PM
BLaCk-S
Mar 18, 2004 09:10 AM
