Need help 0bd0 - obd1
Old Jan 24, 2004 | 01:41 PM
88 turbo crx's Avatar
Default Need help 0bd0 - obd1
hey guys i can use some help, i have an obd0 crx and i converted to obd1.. im using a p28 chipped ecu and i have a d16z6 sohc vtec dizzy. I still have my resistor box on but i do have obd1 injectors. My car wont start.. just turn and turn and then when i take the key out of the ignition it makes a loud pop like it detonated all late
please help me get my car started
Old Jan 24, 2004 | 01:54 PM
Jaesung's Avatar
get some help at jdmhondaparts.com ecu section
Old Jan 24, 2004 | 02:13 PM
MrTodd's Avatar
Default Re: (Jaesung)
Don't worry about the injectors - that's not your problem.
Do you get a CEL?
It's most likely your distributor wiring. How did you wire it up? Where did you get the harness from?
Old Jan 24, 2004 | 02:30 PM
Default Re: (MrTodd)
yes i get a cel 43... but that was on my obd0 ecu.. i havent got it started with obd1 yet, i wired the dizzy up by color and then i guessed on the last two white wires.. i read the fatter white wire which i couldnt tell that it was fatter goes to a green/yellow.. i tried that and it didnt work, then i switched the other white with that and still didnt work, when i take my key out of the ignition about 10 second after turning and turning the motor
it makes a loud *** pop
scooterbuilteh2
Oct 23, 2009 05:34 PM
nickeynick
Jun 29, 2009 08:52 AM
slows2k
Mar 10, 2006 08:09 PM
filthyCREX
35
Feb 20, 2004 05:36 AM
