request pics of Y8 swap!!!!!!!!!!!
Old Jan 24, 2004 | 12:53 PM
YAY!'s Avatar
Default request pics of Y8 swap!!!!!!!!!!!
Ok i have a Y8 intake man on a D15B2 (out of a 4dr) and mu idle is fukd up is there anyone with pics that can enlighten my ***???
Old Jan 24, 2004 | 12:54 PM
JSPECHB's Avatar
Default Re: request pics of Y8 swap!!!!!!!!!!! (YAY!)
Is it off of a auto or manual Y8? Is your car auto or manual?
Old Jan 24, 2004 | 01:13 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: request pics of Y8 swap!!!!!!!!!!! (JSPECHB)
describe messed up: high idle, bouncy(revs up and down), low idle?
1. Check all vacuum connections
2. Did you use all new gaskets? If you didn't buy new ones and start over
3. Check the IACV and FITV (do a search)
4. Check throttle cable tightness
5. Tighten all bolts for leaks
6. Make sure coolant is full and free of leaks
Old Jan 24, 2004 | 01:20 PM
YAY!'s Avatar
its from a manual and my cars a manual and the idle goes up and down
Old Jan 24, 2004 | 01:32 PM
JSPECHB's Avatar
Check for a vacuum leak and clean your IAC. Is the ECU from the Y8 donor car? Or P28?
Old Jan 24, 2004 | 01:43 PM
MrTodd's Avatar
Here's a fairly up to date pic of my engine bay... It's actually using a Z6 block and a Y8 head, so it's not quite what you're looking for.
-I have since relocated the battery, added the LS T/B, blueprinted injectors and converted to OBD-1. I've been using the Y8 manifold for quite some time now.
HTH
Modified by MrTodd at 4:23 PM 1/24/2004
Old Jan 24, 2004 | 03:07 PM
99EKhatch's Avatar
Default Re: request pics of Y8 swap!!!!!!!!!!! (MrTodd)
clean swap
Old Jan 24, 2004 | 03:26 PM
AgentJam's Avatar
Default Re: request pics of Y8 swap!!!!!!!!!!! (99EKhatch)
Hey Mr. Todd does your drivers side mount sit funny? Mine is pressed against the side of the bracket...towards the front bumper.
cancel
18
Jul 26, 2017 06:36 AM
TurboGoKart
Sep 30, 2009 02:53 PM
4drEF
Apr 11, 2009 04:38 PM
thedanny88
Dec 9, 2008 12:53 PM
94_H22_EG_Hatch
Sep 26, 2008 11:36 AM
